M163 autotuner help - MVAgusta.net
post #1 of 6 (permalink) Old 09-26-2016, 10:00 AM Thread Starter
Al-
Al-'s Avatar
M163 autotuner help
Anyone with an lambda module box that can take a picture of the power/CAN connector? Mine came with a harness from a racebike, but when I connect according to the wiring directions to the aux CAN port on my bike, I'm getting a CAN error message. This is using an m227 ecu if that matters. Should I ignore the error message and attempt to configure anyway?
Al- is offline
post #2 of 6 (permalink) Old 09-26-2016, 12:41 PM
hb88xx's Avatar
can you show some pics?
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #3 of 6 (permalink) Old 09-26-2016, 01:21 PM Thread Starter
Al-
Al-'s Avatar
Thanks. I will take some shots tonight. I added a 4 pin deutsch connector to the m163 harness to join the red, black, white, and green wires to the 4 wire auxiliary can port on the bike's harness. Does yours connect to the bike or to the microtec itself with the included cable?
Al- is offline
post #4 of 6 (permalink) Old 09-26-2016, 01:40 PM
hb88xx's Avatar
Lambdasensor cable goes into one of the two grey connectors into m163 and then cabe to, in my case, M226
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #5 of 6 (permalink) Old 09-26-2016, 02:03 PM Thread Starter
Al-
Al-'s Avatar
I guess that's the problem, the 227 box does not have an auxiliary port like the 226, just the coms lead. I think the m163 harness meant for 227 would need to be specific to the box in that case.
Al- is offline
post #6 of 6 (permalink) Old 09-26-2016, 08:10 PM Thread Starter
Al-
Al-'s Avatar
Solved, connect to can on ecu plug not to the bike can. It's not shared!
Al- is offline
