F3 675 upgrade drivetrain from 530 to 520. - MVAgusta.net
  • 2 Post By Donsy
post #1 of 6 (permalink) Old 08-30-2016, 12:56 PM Thread Starter
kayabusa's Avatar
Hi Guys,
I just finish upgrading the drivetrain on my F3 675 with a 520 kit. I got all the pars from Bellissimoto with the new EZ 3D chain.
The only difficult part was the front sprocket nut, that came glue from factory, I used a heat gun to heat it at 130 centigrade and after that came out without any difficulties... oh one more thing I screw the rivet on the link plate I order a new one to try again.
I like to clean everything meticulous before and after so It took me 3 hours to complete the removal and installation.
- Superlite RS8-R Rear sprocket 43
- Superlite front sprocket 15
- Gold EZ GP 3D 520 chain.
The total weight saving is 1 Kg ( 2.22 lbs)
Here are some pics
kayabusa is offline
post #2 of 6 (permalink) Old 08-30-2016, 03:19 PM
Good move on ordering a new link!
post #3 of 6 (permalink) Old 08-30-2016, 07:39 PM
There seem to be a lot of slack on the chain, did you cut it to the right length ?
post #4 of 6 (permalink) Old 06-01-2018, 05:46 PM
GCBC's Avatar
just ordered these sprockets and an erv3 gold chain.
GCBC is offline
post #5 of 6 (permalink) Old 06-02-2018, 05:32 PM
PTsalas's Avatar
I got the same setup, went 1 tooth down on the front and 1 up on the rear to a 44.
Has a lot more grunt now.
PTsalas is offline
post #6 of 6 (permalink) Old 06-02-2018, 10:36 PM
GCBC's Avatar
gonna run the -1+0 and see how it is at the main track I run which should be spot on since it will reach 155 in two spots
GCBC is offline
You may post new threads
You may post replies
