Integrated tail light F3 (Desmo Corse) and Rizoma Veloce resistors? - MVAgusta.net
post #1 of 3 (permalink) Old 08-22-2016, 10:46 AM Thread Starter
markmarkmark's Avatar
Hello all,
So I purchased the integrated tail light from Desmo Corse for my F3. Unfortunately, I cannot get the signal to turn on at all. Brake light works fine.
Do I need a resistor to make the signals work? If so, its a single wire and its internally grounded. What resistor do I use? Most of the resistors I've seen are parallel.
Also, I bought the Rizoma veloce signal mirrors. How the hell am I suppose to tuck away the resistor in that thing? Any help would be great!
Thanks,
-Mark
-Mark
14' F3 675 - Active
07' Ducati 749 - Retired
05' 600RR - Retired
00' 929RR -Retired
markmarkmark is offline
post #2 of 3 (permalink) Old 09-09-2016, 07:40 AM
Angelo-MV's Avatar
Hi,
I just got the same mirrors. I removed the cowl and placed the resistors under the black side pieces inside the cowl. You will need both resistors.
Was a much bigger job than I thought it would be. Also, I didn't notice at first the mirrors actually rotated and thought I had got two left side mirrors so don't be afraid if it takes some effort to twist the mirrors.
Hope this helps even though it has been some time since you asked.
The mirrors are great and do not vibrate at all.
Angelo-MV is offline
post #3 of 3 (permalink) Old 09-10-2016, 09:08 PM
number2's Avatar
are the stock signals LED or regular bulbs. If they are LED you should not need the resistors. Same for the rear, if the stock signals you removed were LED then you do not need resistors. If they were regular bulbs and you installed the LED without resistors you may have burned them out.
number2 is offline
You may post new threads
You may post replies
