Port and polish 2005 1000S - MVAgusta.net
post #1 of 10 (permalink) Old 02-20-2016, 03:22 PM Thread Starter
swissinn's Avatar
I'm pulling her apart for valve adjustment anyways. I've done it before on my car. Is it worth it? I figure 15 hours to complete it.
Ex Silentium Adveho Nex
swissinn is offline
post #2 of 10 (permalink) Old 02-20-2016, 03:51 PM
R1andrew's Avatar
If you can do it, I say why not?
R1andrew is online now
post #3 of 10 (permalink) Old 02-20-2016, 04:23 PM
Tony F's Avatar
If you can improve on the factory's handiwork work, yes why not. Do you have access to a flow bench?
Tony F is offline
post #4 of 10 (permalink) Old 02-20-2016, 04:51 PM
Maximum Velocity's Avatar
If you know what you are doing yes!
What a beast of a motorcycle!
Maximum Velocity is offline
post #5 of 10 (permalink) Old 02-20-2016, 04:52 PM Thread Starter
swissinn's Avatar
I do not. It would just be taking down the sharp casted edges and putting a mirror finish on the exhaust ports.
I have no idea what the factory casting looks like. If it's reasonably smooth I'd leave it alone. If it looks anything like my car head did...could likely free up a few horses.
swissinn is offline
post #6 of 10 (permalink) Old 02-20-2016, 07:08 PM
Deano's Avatar
No expert myself but have attempted a few with good results. Equalising the size of the chambers is probably as important as shape and polish. Make up plates to seal the ports with a hole in the centre (Perspex is good), then with the valve in place and seated measure the capacity of the chambers (inlet and exhaust) with diesel using a measuring burette. You'll be surprised by how much (in cc's) they differ. Open out the ports to the largest measured port cc. How far out the MV ports would be I don't know but on some I've done it has been as much as 9cc.
Deano
Deano is offline
post #7 of 10 (permalink) Old 02-20-2016, 07:13 PM
midget81's Avatar
Personally I wouldn't touch it without a flow bench
Terry
2011 F4
midget81 is offline
post #8 of 10 (permalink) Old 02-21-2016, 06:37 AM
Matt M.'s Avatar
I can't agree more. You will effect the exhaust gas flow and scavenging. Possibly ruining your low end torque.
If you do decide to port the exhaust side, please familiarize yourself with the water jacket locations, and how much material you can remove before you put a hole in one.
Porting and polishing usually nets good results higher up the power band. It's hardly worth the effort unless your racing and the motor is living in high RPM's. Other than that, it could be a waste of time.
Too many unknowns here for me, if it runs fine, I'd leave it alone.
Matt M. is offline
post #9 of 10 (permalink) Old 02-21-2016, 06:47 AM
lefin102's Avatar
+10 yup
even a blind squirrel gets a nut once in a while!!
lefin102 is offline
post #10 of 10 (permalink) Old 02-22-2016, 04:10 PM
I'd agree with taking any dingles off and polishing the exhaust side. Not sure I'd reshape anything though. Might be interesting to see how well the ports match the inlet and exhaust.
Jono is offline
You may post new threads
You may post replies
