1090RR MV Corse Belly Pan installation - MVAgusta.net
 4Likes
post #1 of 42 (permalink) Old 09-04-2015, 03:04 PM Thread Starter
bogie's Avatar
Ok so I finally figured out installing the MV belly pan, which arrived without instructions
For future reference, as its not too obvious where the brackets fit
On the right side you need to remove the rear brake master cylinder assembly and replace with the alternative bracket that is supplied
On the left side remove the side stand switch, then side stand itself. The supplied bracket fits behind the side stand, then reassamble
Replace heat shield on the right exhaust with supplied smaller heat shield, if you still have the OE headers fitted
Remove the OE oil cooler guard and keep the same fasteners to re-use at the front
Trim the mesh, stick down edges with epoxy or similar adhesive
Use single rubber faster and bolt to secure new oil cooler guard to belly pan at the bottom centre
optional - I took the belt and braces approach and lined the belly pan with heat reflective mat
Offer into position, I found it easier to secure the two front fasteners loosely , secure the side fasteners then align and tighten the front.
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
post #2 of 42 (permalink) Old 09-05-2015, 09:30 AM Thread Starter
bogie's Avatar
Some pics of where the brackets go
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
post #3 of 42 (permalink) Old 09-05-2015, 09:34 AM Thread Starter
bogie's Avatar
And after all that, im not sure that I actually like it on bike
I've been pondering for weeks, looking at pics of other bikes and was sure that I really liked the belly pan look....but now im not so sure
Maybe it will grow on me .....or maybe it will be in the classifieds section by next weekend ........
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
post #4 of 42 (permalink) Old 09-05-2015, 02:42 PM
Madjock's Avatar
I'm a bit on the fence if a belly pan works on a Brutale. I've also been pondering about buying one myself though!!
Sharon thinks that it looks really good on your bike.
Only you can decide!!
Dave.
Madjock is offline
post #5 of 42 (permalink) Old 09-05-2015, 04:24 PM
Reopropf's Avatar
Not to my liking.
Reopropf is offline
post #6 of 42 (permalink) Old 09-05-2015, 05:55 PM Thread Starter
bogie's Avatar
Im really not sure, it might be better if it was integrated with the main colour scheme and blue/white ...but I dont really want to spend hundreds more if i dont like it overall...will give it a week and think about it
I really liked the look of it on other owners bikes, most of those were dark colours though and many with single sport pipes.....mmmm
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
post #7 of 42 (permalink) Old 09-05-2015, 07:10 PM
number2's Avatar
it's a naked bike
number2 is online now
post #8 of 42 (permalink) Old 09-05-2015, 08:27 PM
eddypro's Avatar
It is the Color combo ,that's all ,experiment a bit ,they do look good if you get it right.my mate had one on the 1090rr but different scheme.Mine looks good 1078rr.
cheers eddy
eddypro is offline
post #9 of 42 (permalink) Old 09-05-2015, 08:29 PM
eddypro's Avatar
change the grey at the front,maybe
eddypro is offline
post #10 of 42 (permalink) Old 09-05-2015, 09:25 PM
I like it.
