Custom bolts for my Radiator shrouds - MVAgusta.net
post #1 of 21 (permalink) Old 02-28-2015, 11:49 AM Thread Starter
BG Wells's Avatar
OK..,so I got some beautiful little carbon pieces for my Brutale 1078rr http://www.mvagusta.net/forum/showth...37901&page=269
and as usual I wanted to add my own mark on this upgrade.
I have systematically been replacing various OEM bolts and other detail pieces with parts I've been making myself and here was an opportunity to do it again
To be honest I had made replacement bolts for the OEM aluminium shrouds (that I had polished). I made these some tome ago..,and was intending to reuse them.
But I test fitted another similar bolt I'd made in brass and compared it with the Aluminium ones I'd previously made.......and whaddya know...I preferred the brass next to the carbon fibre.
So once again time to crank up the lathe.
Oh and to get the 'hex' recess (for the 'Allen key' to fit) I used my little 'broaching' tool kit for this purpose.
I had made this some time ago.... http://www.mvagusta.net/forum/showthread.php?t=48793
Anyway...enough of the 'chit-chat' .....,lets make something!!
Brian.
BG Wells is offline
post #2 of 21 (permalink) Old 02-28-2015, 11:52 AM Thread Starter
BG Wells's Avatar
Still following?
Ok here is the next sequence to completion
They're tiny little things 12.60mm in Diameter and the 12 holes around their circumference are 1mm in diameter.
I've mentioned this before...,to get the 'Hex' recess....(in this case 4mm) you need to drill the hole 'oversize' @ 4.10mm and then use a corresponding 4.10mm 'broach' otherwise it will be too tight for a 4mm allen key if you just use a 4mm drill bit and broach.
Brian
BG Wells is offline
post #3 of 21 (permalink) Old 02-28-2015, 11:55 AM
lc_brutale's Avatar
Once again, great work.
Chris
2008 Brutale 910R
lc_brutale is offline
post #4 of 21 (permalink) Old 02-28-2015, 12:06 PM
Magic!
post #5 of 21 (permalink) Old 02-28-2015, 12:07 PM
Formerly known as Lumiator
LO111's Avatar
Amazing!
...just for one day.
LO111 is offline
post #6 of 21 (permalink) Old 02-28-2015, 01:16 PM
eduardo's Avatar
I´m speechless...you are The Master.
Thank you for the full picture report of your work, so we can see that from «nothing» you do a Masterpiece!
Da Vinci would be jealous......................................opc orn:
eduardo is offline
post #7 of 21 (permalink) Old 02-28-2015, 01:21 PM
FUSED's Avatar
wow.
The machinery you must own!
FUSED is offline
post #8 of 21 (permalink) Old 02-28-2015, 02:19 PM
doggy's Avatar
Superb!
I struggle to buy the right bolts and you just make your own custom ones!
Brutale 800 Italia
Monster 796 .
doggy is offline
post #9 of 21 (permalink) Old 02-28-2015, 04:49 PM
JDS
King of Bling
JDS's Avatar
Send a message via MSN to JDS
Cool Dude...
Brian..... We've got a couple of spare rooms and a separate bathroom on the other side of the house... When do you want to move in ?
Hell,.. I'd even buy you a new lathe.
Do you ever think of using titanium material when making these custom pieces ?
EMAIL :
JDS is offline
post #10 of 21 (permalink) Old 02-28-2015, 05:06 PM Thread Starter
BG Wells's Avatar
Yes John., and funny you should mention that...,I was looking a a few pieces of Titanium just the day before yesterday for this very job.
Maybe next time
BG Wells is offline
