Bolt torque important when fitting rear sets? - MVAgusta.net
post #1 of 5 (permalink) Old 02-02-2015, 03:47 AM Thread Starter
Well I now have the new rear sets sitting in the garage ready to be fitted. Is this something straight forward I should do myself or should I take it to the dealer? The instructions state I should tighten the bolts to manufacturer torque settings and apply locktite. My issues though are a) I don't own a torque wrench and b) I've no idea what the manufacturer specs would be. Can I just tighten them normally or is the torque level important?
Troz is offline
post #2 of 5 (permalink) Old 02-02-2015, 04:15 AM
Lightbulb
a. Can you borrow one quickly, or do just as I know some blokes do (And I did not tell you this), undo the bolts taking note of the paint marks on the bolts, re-tighten to the same point with new Loctite on the bolts.
b. Really, have a look at the "indicated all over the forum website", and download the workshop manual, it might save your arse one day.
post #3 of 5 (permalink) Old 02-02-2015, 04:20 AM Thread Starter
Cheers mate. Will do. I'll also give myself an upper cut for being a lazy sod! And buy a torque wrench while I'm at it.
EDIT - Dumb question for the day. When the workshop manual says to tighten the bolts to 24 ÷ 28 Nm does that mean tighten them to somewhere between 24 and 28 Nm? Or something else entirely?
Troz is offline
post #4 of 5 (permalink) Old 02-02-2015, 07:41 AM
gotojoe's Avatar
Nothing dumb about asking for clarification...It's a range, so lower value 24 Nm and higher 28 Nm. Within this range is safe.
Bear in mind though that these values are with reference to a dry thread or a lubed thread as per manual as this affects the bolt stretch...
joe
gotojoe is offline
post #5 of 5 (permalink) Old 02-03-2015, 04:12 AM Thread Starter
Cheers guys - appreciate it
Troz is offline
