are ECUs interchangeable - MVAgusta.net
post #1 of 10 (permalink) Old 12-07-2014, 01:03 PM Thread Starter
number2's Avatar
can an ecu from an F4 be installed on a brutale?
number2 is offline
post #2 of 10 (permalink) Old 12-07-2014, 01:13 PM
A 5SM can be installed on any bike that uses a 5SM. Same with the 1.6M.
HOWEVER, it will have to be tuned to the bike. Brutale motors and F4 motors have differing specs...even if you go from 1078 to 1078.
post #3 of 10 (permalink) Old 12-07-2014, 05:49 PM
Post
So in short, no, not as a standard unit.
Just as a definite answer for guys who are not aware of the rare option of re-writing the stck ECU software Chuck.
post #4 of 10 (permalink) Old 12-07-2014, 06:11 PM
AusMV312's Avatar
F4 Ecu
With regards to Flashing/re programing the stock ECU.....what goes on in this case? Who can do it? How will it change the performance of the bike. I read that the Microtec ECU is the best option but pricey.
Is there somebody in the SW that does this Donsy?
Current 2008 F4 312R
Track Bike
Past '93 Ducati 900 SS
'82 Suzuki GSX 1100 SZ Katana
? Suzuki GS 850 G Shaft Drive
? Honda XL 500
'82 Suzuki GSX 750 SZ Katana
'76 Honda CB 750 Four K6
In my Youth Suzuki RM 80 C
Yamaha YZ 80 C
AusMV312 is offline
post #5 of 10 (permalink) Old 12-07-2014, 06:23 PM
I don't even think there's anybody in Australia who does this Steve. Powercommander is the only other option for you if Microtec is out of reach.
post #6 of 10 (permalink) Old 12-07-2014, 07:30 PM Thread Starter
number2's Avatar
using the 1078 as an example, are the motors physically the same or are the cams different between the brutale and the F4?
number2 is offline
post #7 of 10 (permalink) Old 12-08-2014, 06:23 AM
I am pretty certain the cams are one of the biggest differences....in the engine.
post #8 of 10 (permalink) Old 12-08-2014, 06:34 AM
gotojoe's Avatar
They are listed on Startwin's web site...if you wish to compare parts,
joe
gotojoe is offline
post #9 of 10 (permalink) Old 12-08-2014, 07:01 AM
Maximum Velocity's Avatar
Design Corse is doing reflash...
http://www.designcorse.com/shop/mv-a...mapping-detail
What a beast of a motorcycle!
Maximum Velocity is offline
post #10 of 10 (permalink) Old 12-08-2014, 09:10 AM
AS Donsy has noted, reflashing the 5SM or rechipping the 1.6M is possible.
The maps are only as good as the bike and the bloke who took the time to do the work.
I learned through Curis's Senna that engine internals (think cams and valve timing) have a massive effect on the outcome of a reflash.
In other words: If it isn't the same year and model engine, the mapping likely won't transfer well.
The MicroTec through Chris at X-Bikes is an excellent option with superlative customer support.
Custom mapping an ECU requires hours of Dyno time and multiple ride passes in the real world to get it right. Getting my 312R to ride like it does took a couple of days and around $850.00 USD.
If you don't have access to a dyno and a GOOD tech, I'd go with Chris at X-bikes. The price isn't all that different.
Flashing someone else's map into your ECU will give you the results that THEY wanted...may not be what you want to achieve.
