Sprocket question - Page 2 - MVAgusta.net
post #11 of 16 (permalink) Old 07-20-2014, 11:54 PM
99sitr's Avatar
Donsy I'm currently looking at a standalone shift light set. The F3 is so hard to see and I want to set mine at about 11,5 when the bike is making peak numbers. I've seen a few online but are kind of clunky looking.
Cheers, Jon-Michael
2014 F3 800 EAS
2013 F3 675 EAS
99sitr is offline
post #12 of 16 (permalink) Old 07-21-2014, 09:34 AM
Originally Posted by richd748 View Post
I obliviously know 7000 is not redline (it does not read 7=redline). I try to maintain my rpm's between 7000 to redline. Coming into some tight corners it comes down to 7000 or a little lower but 1st gear would not be appropriate.
My bad, I interpreted that as riding mostly around 7k...not 7k+....sometimes I'm a bit slow in the thought process..
Regardless, the advice on selecting gearing is the same.
COTA has a straight where the MotoGP boys routinely go well over 200+ mph. That track looks to be a fun and very fast ride. Wish I could join you..
post #13 of 16 (permalink) Old 07-21-2014, 07:20 PM Thread Starter
richd748's Avatar
I will definately post some GoPro video from COTA.
richd748 is offline
post #14 of 16 (permalink) Old 07-25-2014, 12:29 PM Thread Starter
richd748's Avatar
I was going to go up 2 teeth on the rear for my 2007 F4, dealer has a 43T brutale sprocket which he thought was 2 teeth up. Realized this is actually 3T change. What do you think about going up this much, next track day is next weekend and I could get it done quick since it is in stock. The two tracks I mainly run are 2.5 and 1.7 miles, usually only get to 4th gear on the straights. Don't want to turn it into a wheelie machine. Would you recommend I just order a 42T?
richd748 is offline
post #15 of 16 (permalink) Old 07-25-2014, 12:33 PM
BSR-1's Avatar
Go for it! 3 in the rear is (very) roughly -1 in front. It's a good change but not too big.
2018 Husky 701 Supermoto
2018 Aprilia Tuono 1100
BSR-1 is offline
post #16 of 16 (permalink) Old 07-28-2014, 02:36 AM
Wink ?
15x40= 2.667
15x43= 2.867
or 7% difference
