1090 RR Wheel bearings - MVAgusta.net
post #1 of 20 (permalink) Old 12-27-2013, 09:29 AM Thread Starter
steve1968's Avatar
Hi all
Just taken the front wheel out of my bike for the first time and the bearings feel quite knotchy to say the least , can anyone advise on any particular brand i should be replacing with ?
Any tips for removal of the old ones would also be appreciated , i asume the size i require will be on the bearing .
Not very impressed with the quality at all - took the front out of my 04 Bonnie also this afternoon and the bearings felt brand new .
Any advice welcome .
Steve
steve1968 is offline
post #2 of 20 (permalink) Old 12-27-2013, 09:35 AM
Que, The Knurl......
post #3 of 20 (permalink) Old 12-27-2013, 10:03 AM
Either carefully knock them out with a long drift punch, working around the perimeter or use a proper bearing puller.
Alternatively, heat can be used to expand the wheel away from the bearing so it "falls" out.
Bearing size and type should be on the outer race. You can also measure the ID -OD and width and go on a search.
Spend some serious money and get ceramic bearings.....then you can brag about them, even if you don't realize any street use benefits..
But The Knurl will have better information on bearing grades and other R&R methods.
post #4 of 20 (permalink) Old 12-27-2013, 01:54 PM
revhead1957's Avatar
Original bearings are imprinted with 'made in France' they were crap. 8000km iirc. Replaced with generic, probably Chinese. Up to 40,000 km now with no further issues. Go figure.
It is a lot easier if a proper bearing puller is used to remove them.
revhead1957 is online now
post #5 of 20 (permalink) Old 12-27-2013, 07:01 PM
Wink ?
MV front wheel bearings;
they are 6907-2RS bearings, 35mm x 55mm x 10mm
Steve;
I've got them here on my table, where are you on the blue orb?
PM me
Ed;
I wouldn't use heat......probably ruin the paint on the wheel
Jon;
you have the best answer.....but I can't afford a SnapOn internal bearing puller set......so its the long brass punch way
post #6 of 20 (permalink) Old 12-28-2013, 05:47 AM
MVAgusta.net Sponsor
mitchy's Avatar
The front bearings on my 1078 felt notchy at a low mileage,and a further check I discovered it was the centre spacer being too long putting too much load on the bearings.Slight machine off the spacer and all was fine.The bearings were perfect,the load by the spacer was giving a false indication that the bearings were notchy.
Bike- F4 1078.
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
post #7 of 20 (permalink) Old 12-28-2013, 05:58 AM Thread Starter
steve1968's Avatar
Steve;
PM me
Ed;
Jon;
Hi Noel
I'm just round the corner .......in the UK .
Steve
post #8 of 20 (permalink) Old 12-28-2013, 06:02 AM Thread Starter
steve1968's Avatar
Are you saying that the length of the spacer is greater than the distance between the seated bearings ?
If so by how much ?
Either way i assume i will still need new bearings .
post #9 of 20 (permalink) Old 12-28-2013, 06:13 AM
mitchy's Avatar
If so by how much ?
Yes,the lengths of the spacers seem to be inconsistent,mine was 1mm too long and some are too short.Use your bearing puller to move out 1 bearing slightly and re-check the 2 bearings for smoothness,you might get a surprise and see the bearings are quite OK.Just trying to save you spending money when you don't have too.
Bike- F4 1078.
Mobile-0423041326
mitchy is offline
post #10 of 20 (permalink) Old 12-28-2013, 07:46 AM
gotojoe's Avatar
Uk Grammar poleeece here ... " cue" the Knurl
gotojoe is online now
