MV Brutale poor low rpm throttle response - survey - Page 6 - MVAgusta.net
View Poll Results: Low RPM throttle problem on MV Brutale?
Did not have this problem with my Brutale 20 32.26%
Got problem fixed under warranty 0 0%
could not get it fixed under warranty spent my own cash with a specialist 8 12.90%
Still have the issue just putting up with it 28 45.16%
other 6 9.68%
Voters: 62. You may not vote on this poll
 3Likes
post #51 of 69 (permalink) Old 10-02-2016, 10:56 PM
eddypro's Avatar
You are just fooling the ecu
eddypro is offline
post #52 of 69 (permalink) Old 10-27-2016, 08:49 PM
Did the MV guy get you sorted? I have a 2012 1090R and have been having persistent cold stalls, 5 this morning in San Diego where it aint exactly cold. GP cant seem to find then problem, they reset the TPS last time it was in but it didn't cure it. Any ideas? as i'll be changing it for a 2017 I don't want to fit a Power Commander or similar.
pete
PBMV4 is offline
post #53 of 69 (permalink) Old 10-28-2016, 10:05 AM
Throttle Body Balance
post #54 of 69 (permalink) Old 10-28-2016, 06:46 PM
Thanks, GP increased the idle and that seems to have cured it.
PBMV4 is offline
post #55 of 69 (permalink) Old 10-30-2016, 08:00 PM
I am currently working with David at Rexxer on getting a cable that works with my 2013 ECU OBD. I'll let you know when it is reflashed with the Rexxer map, TPS reset and how it runs. FYI, speaking with the MV North America rep he said it is as simple as a TPS reset for Magnelli ECU's. I'll reset the TPS before installing David's map so I can see how much that solves our issues. I know that alone has not solved problems for others, but figure with the Rexxer I can get it tweaked by my local tuner (Rexxer) if necessary.
steelmill is offline
post #56 of 69 (permalink) Old 08-09-2018, 01:25 PM
I know I am necrobumping the hell out of this thread but I didn't want to make a new one.
I have a 2012 Brutale 1090R and the RPMs below 3K do not exist. I have grabbed the throttle while in N with two hands and slowly slowly slowly turn the throttle to get it to 1.5K-2.5K and it is almost impossible. The bike shoots RIGHT up to 3k and makes riding at slow speeds and stop and go traffic very frustrating. Like others have commented, I look like a new rider on this thing taking slow corners, making anything relatively slow a chore to make sure I don't chop the throttle. Is this just the bike, is it the TPS, is it the ECU? I have read a few posts on here and not sure where to start. Any assistance would be appreciated.
-Anthony
Acid32 is offline
post #57 of 69 (permalink) Old 08-09-2018, 01:38 PM
Start with adjusting your throttle cables.
post #58 of 69 (permalink) Old 08-09-2018, 03:02 PM
lucydad's Avatar
Fueling on 2018 Brutale Dragster 800 RR is excellent at any RPM. First gear is pretty tall compared to my other bikes, but yes the machine is extremely smooth in any conditions.
Never ride faster than your guardian angel can fly....
2018 MV Agusta 800 Brutale RR-- "Betttina" in Giallo-Nero
lucydad is offline
post #59 of 69 (permalink) Old 08-09-2018, 04:29 PM
revhead1957's Avatar
Acid32, you will find a few threads about this.
It is the nature of the design that there is a jump from idle to 2000rpm. It is the way the ignition curve is set up, so adding a fuel adjusting device is not going to fix it.
Low speed riding will require slipping the clutch together with a lower gear and more revs.
revhead1957 is offline
post #60 of 69 (permalink) Old 08-09-2018, 04:38 PM
The reference idle on a 1090R is 1100-1200 RPM.
Snatchy throttle response is likely caused by unbalanced Throttle Bodies and poor set-up of the throttle cables.
ECU tuning also helps.
You may post new threads
You may post replies
