3800 Mile Service... - MVAgusta.net
post #1 of 43 (permalink) Old 08-25-2013, 08:06 PM Thread Starter
Timber29's Avatar
It was going great until I needed to put the gas tank back on...then I noticed the plastic 90 degree fuel tank connector on the bottom of the tank was cracked. I was super careful then the wife comes out...
So I drained the tank and now it sits until I figure out how to get it fixed. I did notice some fixes for the fuel tank connector on the previous model year and was wondering if that would work?
Timber29 is offline
post #2 of 43 (permalink) Old 08-26-2013, 12:39 AM
MVAgusta.net Sponsor
mitchy's Avatar
You need to fit a pair of metal fuel connectors.Buy them off Carl (CAG),then read up on how to fit them.Good luck.
http://www.mvagusta.net/forum/showthread.php?t=39000
Bike- F4 1078.
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
post #3 of 43 (permalink) Old 08-26-2013, 03:28 AM
There's some useful tips in here - http://www.mvagusta.net/forum/showthread.php?t=39000 - read the whole thing, lot's of idea's in there.
CAG , unfortunately does not sell the fittings anymore, but most of the forum sponsors do now days.
post #4 of 43 (permalink) Old 08-26-2013, 09:32 AM Thread Starter
Timber29's Avatar
Thanks guys for the help!
Timber29 is offline
post #5 of 43 (permalink) Old 08-26-2013, 04:17 PM
mitchy's Avatar
Sorry Donsy,did not realise Carl does not sell them anymore.Missleading information
Bike- F4 1078.
Mobile-0423041326
mitchy is offline
post #6 of 43 (permalink) Old 08-26-2013, 06:55 PM Thread Starter
Timber29's Avatar
So looking in the service manual I'm a tad confused on the fuel pump O ring. I only have one O ring and I put it in position 1 (the notch) and fuel leaks. I put in position 2 and same thing. Am I supposed to have two O rings? The parts breakdown doesn't help spell it out for me either. I've inspected the O ring also and it looks good...
Timber29 is offline
post #7 of 43 (permalink) Old 08-26-2013, 07:26 PM
Wink CPC metal fittings?
Donsy and Mitch they won't help him, he has a '10 bike with a single red John Guest fitting on the bottom
and it has 3 hose fittings in the pump plate the old bikes had 2
Timber29;
you need to remove the cannister, if you have it (since i don't know where you are) and wye the drain/vent lines together INSIDE the tank
make them ~20cm/8" longer than stock.....then you can change the fuel filter without disconnecting the vent/drain lines
epoxy 2 of fuel pump plate fittings closed.....that way you only need to remove 1 clamp the remove the fuel pump completely
the plastic tank MVs use 2 of the big O-rings .....my '08 910R came with only 1
but didn't leak
lucky me
post #8 of 43 (permalink) Old 08-26-2013, 07:39 PM Thread Starter
Timber29's Avatar
Timber29;
but didn't leak
lucky me
Yes, I have a Walkman (canister) in my fuel tank also since I’m a California resident. So how in the wide world of sports do I only have one O ring in my tank (the green one)? Also how the #[email protected]! Do you get the red fitting off at the bottom of the tank?
Timber29 is offline
post #9 of 43 (permalink) Old 08-26-2013, 08:01 PM
mitchy's Avatar
Opps,stuffed up again.I looked at his registry and saw F4 1000 and went by that info.
Bike- F4 1078.
Mobile-0423041326
mitchy is offline
post #10 of 43 (permalink) Old 08-26-2013, 08:50 PM
mitchy's Avatar
Originally Posted by Timber29 View Post
Yes, I have a Walkman (canister) in my fuel tank also since Iím a California resident. So how in the wide world of sports do I only have one O ring in my tank (the green one)? Also how the #[email protected]! Do you get the red fitting off at the bottom of the tank?
That fitting does not separate from the pump housing.I did a search for you and MV sells the complete assembly for around $900.00.I found a post where a bike shop did a conversion and fixed a John Guest male elbow into the pump housing.Hopefully another member has a quicker solution for you.Name:  61427.jpg
Bike- F4 1078.
Mobile-0423041326
mitchy is offline
