7,500 service question regarding a full exhaust - MVAgusta.net
post #1 of 12 (permalink) Old 08-06-2013, 09:48 PM Thread Starter
SAB
SAB's Avatar
Bike: 2007 F4 Senna
Would it make more sense one way or the other on fitting an full Arrow Competition exhaust and PCIII before/after bringing the bike in for it's 7,500 service?
As she sits now she is completely stock.
I can't imagine it would, but it can't hurt to ask. Thanks in advance!
- Seth
"If I'd never thrown my leg over a bike, I'd never have lived." - Hislop
SAB is offline
post #2 of 12 (permalink) Old 08-07-2013, 12:13 AM
jimboF4's Avatar
Seth,
During the service would make most sense, as the service involves a good amount of removal of bodywork, fuel tank airbox etc. While the bike is in pieces it would not be a big step more to remove the radiator and fit the exhaust system also the PCIII.
jimboF4
jimboF4 is offline
post #3 of 12 (permalink) Old 08-07-2013, 01:10 AM Thread Starter
SAB
SAB's Avatar
Originally Posted by jimboF4 View Post
Seth,
jimboF4
Jim, I appreciate the response but I think I wrote what I was trying to ask a bit unclear.
I'm capable of fitting the exhaust and PCIII myself. My question was in regards to the adjustments that they make during the service being effected one way or the other based on if the system is fitted prior to going into the service.
In other words, should I put the exhaust on before it goes in or wait until it comes back? Does it matter one way or the other?
SAB is offline
post #4 of 12 (permalink) Old 08-07-2013, 01:58 AM
Smile
Hi Seth
If you're going to a full race system, you will have to get the bike dyno tuned in any case, are you fitting another ecu or PC ?
And you don't have to remove the radiators to install new exhaust.
post #5 of 12 (permalink) Old 08-07-2013, 02:03 AM
jimboF4's Avatar
Hi Seth,
OK, then I would say it does not really matter either way. I guess you are going to have the PCIII setup on a dyno, that does put a bit of a strain on an engine so having new oil and valves clearances checked before the run would be my preference.
jimboF4
jimboF4 is offline
post #6 of 12 (permalink) Old 08-07-2013, 02:06 AM
Thumbs up +10
jimboF4
Yup
post #7 of 12 (permalink) Old 08-07-2013, 02:09 AM Thread Starter
SAB
SAB's Avatar
Hi Seth
Dons the bike will most definitely be going to the tuner after the system is fitted. CAG uses the same tuner that I used for my R1, so I'm going to give the PC a shot before trying another ecu.
My concern was if it made any difference to the adjustments that are made during the 7,500 service if a full system and pcIII is on or not.
Hi Seth,
jimboF4
Good to know Jim..That makes sense. Thank you.
SAB is offline
post #8 of 12 (permalink) Old 08-10-2013, 01:03 AM
Hi Seth
wrong.....
any idiot can fuel a motor on the big end......you just need a lambda meter
how are you going to do the transitions on a dyno?????
you know, the ugly little stumbles and snatches that make bikes a POS to ride
datalog it while riding around......thats the real world.....wait....... you have a caveman alpha/N system that doesn't reference MAP, brilliant
my buddy Bob is building a 2nd dyno.....his other one won't deal with 700HP RACE bikes.....and you can't tune streamliners on the street
you have 375HP turbo Gixxer? tune it on the street
Henry Louie's street bike, daily driver......yes, daily driver
http://www.rbracing-rsr.com/cinema/suzukiturbo1.mov
Henry was the President of SCTA the people that RUN Bonneville and El Mirage
my friend JW got his 200 MPH card on Henry's bike at 208+
here are some calculators for you folks;
http://www.rbracing-rsr.com/calculations.htm
post #9 of 12 (permalink) Old 08-10-2013, 03:28 AM
wrong.....
I'm so happy for you Noel, I wish I was any idiot.
There you go Seth, all the info you need.
post #10 of 12 (permalink) Old 08-10-2013, 08:13 PM
Wink
ever see the line at A/F 13.5 on a dyno chart?
that's maximum steady state HP
max acceleration A/F ~12.8
on decel or over run pull the fuel to ~A/F 17 but add timing
data log what your bike is doing then fix it
