2013 F4 Quickshifter - not working - Page 8 - MVAgusta.net
post #71 of 88 (permalink) Old 07-05-2013, 10:10 AM
Wink
Originally Posted by TheCatWhisperer View Post
Can somebody explain to me what exactly this quickshifter is and how it's supposed to work?
i.e. Is it just a normal standard gearbox and the quickshifter just cuts the ignition when the lever is travelling and the clutch is left out?
I can do clutchless up and down shifts on my MY10 almost every time without issue, though obviously I have to do the blipping myself with the throttle.
So, what's the issue with the 13s? Is it not auto-blipping, or is the gearbox not engaging clutchlessly?
If it's the gearbox, then I can't imagine any map update is ever going to fix it.
Si
Oh my goodness Si.
Here goes - quickshifter allows gearchanges without backing of on the throttle, and no clutch lever use either. So you just wait for the right time, and apply the foot pressure in a very positive manner.
Watch the video, excuse the bad start, the plates where very old, but keep an eye on the hand and listen to the gears changing. http://www.youtube.com/watch?v=wB9zavd20-M .
Like I mentioned B4, this does not work on low rpm's on most bikes.
post #72 of 88 (permalink) Old 07-05-2013, 02:45 PM
Sorry, I didn't mean I don't know what a quick shifter is, I just wanted to know what technology it employs on the '13.
So there's nothing different about the gearbox? It's just an auto-blipper? It's not like the gear selection is servo assisted or anything?
So when people say their quick shifter is not working on their MY13s, are they saying it's not auto-blipping or are they saying their gearboxes aren't allowing the engagement of the next gear?
I can't do clutchless changes at low revs on my '10, but then I wouldn't expect to be able to, so if the gearbox is the same and the QS is just a blipper on the '13, then I wondered whether half the problem is some people might be expecting more from it than it's capable of?
Si
TheCatWhisperer is offline
post #73 of 88 (permalink) Old 07-05-2013, 11:40 PM
Smile
Si the Auto blipping is only related to downshifting. And you are right I think in your train of though in what people are expecting.
post #74 of 88 (permalink) Old 08-01-2013, 10:50 AM
Delloco's Avatar
Send a message via Skype™ to Delloco
Update
I got my bike back after clutch replacement. I have noticed big improvement with the quick shifter, the torque has been adjusted and the gears are working like in HP4. One problem solved
I think I'm gonna stick to mv
BMW K1200 R 2008 sold/ F4R 2012 sold / F4RR 2013
Delloco is offline
post #75 of 88 (permalink) Old 08-02-2013, 03:20 PM
juan felipe rodriguez's Avatar
Hello friend besides changing your clutch made ​​for the quickshifter work?? know if you updated your ecu??
regards
Juan
juan felipe rodriguez is offline
post #76 of 88 (permalink) Old 08-03-2013, 10:00 AM
Delloco's Avatar
Nah, the clutch failed after a few attempts to launch the bike. The quickshifter has been adjusted meaning the level of torque that is required to change the gear. I had no problems for 2 days, I've done about 300 km and now I'm getting various results. Sometimes it works and sometimes I have to just kick it.
Delloco is offline
post #77 of 88 (permalink) Old 08-03-2013, 07:12 PM
mvrick's Avatar
It seems like the timming is to slow on the QS. It means that the gear engage first before the QS.
I had same issue when I was adjusting my own QS.
I feel the need, the need for corner speed!
Rollen Artwork.
mvrick is offline
post #78 of 88 (permalink) Old 08-21-2017, 02:17 PM
ARAMIS's Avatar
I've a doubt, does the 2013 F4 have the eas 2.0 quich shift or it was later introduced?
ARAMIS is offline
post #79 of 88 (permalink) Old 08-25-2017, 06:00 PM
From talking to Gabriele at Evolution Bike, my understanding is that the auto blip on the downshift isn't going to be available through a software update unless you have the EAS 2.0 sensor. I have a 2016 F4RR and mine unfortunately didn't even come with the crappy translogic QS. I ended up purchasing it through Evolution Bike and then when I found out about the kit part with the EAS 2.0 I exchanged it for the kit part.
When the kit part arrived it will only do the upshift but it comes with a code for the dealer to download an updated map that will turn on the auto-blip function for downshift.
This may be the map people are expecting to come as a future update but I fear that it may only be available with the purchase of the kit with EAS 2.0
stickmandj is offline
post #80 of 88 (permalink) Old 08-27-2017, 02:41 PM
ARAMIS's Avatar
Do you've a link for the kit with EAS 2.0?
ARAMIS is offline
