Valve Shims - MVAgusta.net
post #1 of 19 (permalink) Old 01-17-2013, 06:39 AM Thread Starter
Question Valve Shims
Anybody have a re-liable source for the under-bucket shims we use on the MV's ?
post #2 of 19 (permalink) Old 01-17-2013, 08:17 AM
gotojoe's Avatar
Hi Donsy, Here's a post from a forum member back in 09...It seems they are in common with some Honda models..possibly Yamaha.
I have a 2006 F4 cylinder head here. If you want me to get the diameter of the shims measured so that you can go into a Honda dealership armed with right info then let me know..
joe
So just in case anyone is wondering... if you do a valve job and need shims CRF250 shims are identical to the MV shims I dont know if this is common knowledge or not but I thought I would pass it along.
gotojoe is offline
post #3 of 19 (permalink) Old 01-17-2013, 08:21 AM
Joe, I have some shims from a shim kit that was used for a Kwaker ZX-11. If you measure the diameter, I'll check my Kwacker shims to see if they will work....
post #4 of 19 (permalink) Old 01-17-2013, 08:22 AM Thread Starter
Thanks Joe, if you can just measure the outside dia for me, I have none here, then I can ask my friend over here in the Honda shop.
I remember someone posting about a kit, as MV recommends certain min/max thicknesses.
post #5 of 19 (permalink) Old 01-17-2013, 08:22 AM Thread Starter
You boys are legen......dary
post #6 of 19 (permalink) Old 01-17-2013, 08:29 AM
Dons, if it turns out the Kwaker shims will work, I'll send them your way.
post #7 of 19 (permalink) Old 01-17-2013, 09:41 AM
gotojoe's Avatar
7.48 mm is what mine measures to. and collective wisdom seems to corroborate this dimension as a standard used by Kawasaki , Honda, Yamaha and Suzuki.
Mine has 205 stamped on it....
There are ebay sellers for shim kits. Hot cams seems to be popular...
gotojoe is offline
post #8 of 19 (permalink) Old 01-17-2013, 10:54 AM
MihaSLO's Avatar
Yes, they are standard for Honda, Kawa and others. MV specifies the allowed thickness to be between 1.60 and 2.60 mm.
If you don't find the exact one, you can also brush them against sandpaper layed on a glass to get a few 0.01s off. It worked couple of times for me.
Or if you want to have a blueprinted engine, for instance and you can all put them on same clearance.
One race team that will run F3 this year just rebuilt the engine to the tolerances and gained 3-4 HP.
MihaSLO is offline
post #9 of 19 (permalink) Old 01-17-2013, 11:30 AM
so, that's 0.294 inches for us metrically challenged folks....?
post #10 of 19 (permalink) Old 01-17-2013, 12:20 PM
gotojoe's Avatar
yes indeedy
I should have brought my pet Cylinderhead over to show you Chuck ; )
gotojoe is offline
