When I first picked up my 312R I got stuck in a Melbourne traffic jam on a warm day and had overheating issues 120C+.
Based on what I found on the forum one of the first things I did was install a manual fan switch. I also flushed the radiator and changed to Penrite race coolant
On our first 30C+ day recently I decided to see if turning the fans on at 80C would stop the overheating. Unfortunately although it slowed the temperature continued to rise and at 110C coolant was discharged. I found that the water pump inlet hose had disconnected. Maybe I didn't put it back properly when I replaced the leaking seal.
The next day I reconnected the water pump hose and checked the coolant level. Strangely the level seemed to be higher than normal. I started the bike to check for leaks. The dash kept flashing --- less than 50C. I then noticed the fans had turned on automatically so I quickly shut it down.
Once it had cooled down I found the coolant level was still high. I checked the coolant at the water pump drain and found very little. The coolant didn't seem to be getting from the tank to the pump. I tried blowing back along the hose from the tank. Blocked. Dismantled everything and removed the coolant tank and found coppery goo.
Flush the radiator again. I assume the previous owner used Stop Leak when he had radiator leak.
I had fitted one of Joes brackets. While it was all apart based on the forum I decided to fit an extra Ducati 1098 fan. I tried to remove the Ducati brackets without much success and didn't see the point in replacing them. I wanted the brackets to support the radiator. I only had some aluminium sheet so bent it into "[" section and laminated to strengthen. I wouldn't have believed how long it took me to get them right.
Put it all together soon and see what happens. Hopefully I haven't cooked something.
Getting rid of the catalyst and installing a MV Race ECU provided the greatest relief to high operating temps on my 312R. I added the MV high output water impeller which may have helped a little, and the Muzzy fans prevented the issue of melted fan blades. Other than that, just don't come to a stop - keep moving to keep air flowing! >
Have fibreglass wrapped headers to reduce heat to fan blades and belly pan. Metal fan blades hard to source in Oz. Race ECU maybe next. $. Would much prefer to keep moving but want to be prepared if I get caught again.
I got a 1098 fan from ebay for about $50 making it the most cost effective option.
At this stage I have just connected it to the existing fan.
Fired it up without the fairing and switched the fans on at 80C. Temperature started to come down and stabilized at 75C. Put the fairing back on and repeated the test. Temperature didn't drop but stabilized at 80C. Obviously modified fairing would help but not ready to hack into them yet or lash out on Catalyst fairings. However it was a pretty cool day so will have to wait until it warms up a bit to test properly. Will see what happens before tracking down someone who can tune or replace ECU.
The "Race" ECU is simply a remapped Magneti Marelli 5SM ECU that has the Lambda Sensor input disabled. It is also remapped for a free flowing exhaust. I do not know if it has any changes to the ignition timing from thestock 5SM ECU.
In my opinion, it is a waste of money as it will still have to be mapped for your bike. Anyone that can do that can also map your current ECu to the same, or better, standard.
Options exist that include send in your ECu this way, having mapped to a better base map, and returning it to you.
In addition, the Microtec ECU is a great solution.
There maybe a couple of options for remapping 5SM ECU locally (3 to 4 hours away) that I will follow up on after see what happens with warmer weather. Failing this silentservice do you mean you can remap 5SM ECUs?
Re "Race" ECUs I agree with you but was really referring to the Microtec ECU from Xbikes which I will need to save for.
Yeah I didn't mean to imply that the MV Race ECU in and of itself has any bearing on achieving lower operating temps. As Chuck said, it (or equivalent mapping) is recommended once you eliminate the catalyst. I feel like removing the catalyst did make an impact on lowering operating temps somewhat though.
Arnie;
You need to seal the 2 MV fans to the radiator like on single fan Brutale radiators
Also move the wiring harness on the right side of the motor were it blocks airflow
Got some rubber trim from Clark Rubber local rubber supply co but interfered with fan. May try gluing seal only on the outside. Still looking at optimising wiring.
Hey Arnie,
Really sounds like you have air in the cooling system.
I discovered that filling the cooling system takes a little technique and a little patience in order to ensure that the air is purged.
If this isn't done the bike can run hot and be burping coolant after parking up.
So, cutting to the chase try this from cold :-
Take off the header/ expansion tank filler cap.
The coolant level should be at lower mark minimum for this procedure.
Start the engine.
Let the temp rise to about 80 deg C.
Switch off.
Tilt the bike left to right say 10 times to help bubbles rise and emerge.
( good to have a buddy help so you don't drop the bike ).
Let the bike cool off for ten or 15 mins and then repeat.
I do this procedure about 6 times.
Let the bike cool properly and then top up coolant to minimum level.
Fit the cap back on.
Go for a ride.
Keep an eye on temps and if the bike is still burping coolant after parking up.
If required repeat the procedure by taking the cap off again once cooled down.
I leave the steering damper off for a few rides so that access is easier.
I had no problems once I adopted this approach.
There are so many nooks and crannys in the cooling system where air can hide.
On the electrical side, If the air pressure sensor fails your bike can run very very hot as the mixture can become too weak.
How do I know ? !!!
Joe
When leaving the damper of, remember to remove the little clamp from the upper yoke. Otherwise it will lock the steering in full left turn.
Related Threads
MV Agusta Forum
1M posts
55.7K members
Since 2005
