Installing a new panel - MVAgusta.net
post #1 of 3 (permalink) Old 08-23-2019, 10:21 PM Thread Starter
ANGELOMGR's Avatar
Hello my Brutale 1090 RR broke the panel screen (speedometer) I will buy another, my question is how to configure this new panel with the ECU. Do I need a specific device or can it be configured through the panel itself?
ANGELOMGR is offline
post #2 of 3 (permalink) Old 08-26-2019, 11:55 PM
Farshore's Avatar
The 1090rr dash is an active component of the immobiliser system. Simply replacing it will prevent the bike from starting. If you message me I’ll walk you through what’s required.
09 F4 312 1000
Farshore is offline
post #3 of 3 (permalink) Old 08-28-2019, 03:40 PM Thread Starter
ANGELOMGR's Avatar
Hello Farshore, thank you in advance for your attention. Then I explain my situation to you: My 1090 broke the speedometer screen, I bought another (used) by eBay It didn't start because it was coded. So we just changed the splint, put the dashboard screen that I bought on the original bike dashboard ... got the right mileage, the bike from the start of the mind if I enter the immobilizer code, if I turn off the key it won't turn on more, only if I enter this code again. Then we reset this panel .... now when I put the key the message appears: "invalid key", after that I bought a set of new keys with original code card Mv Agusta thinking that the problem would be the keys or the antenna and the message "invalid key" continues. I do not know what else to do .... I am thinking of buying another panel, but I am afraid of not working, because it is an expensive piece .. with your experience what you suggest me? Thank you!
