F4 2000 Top Yoke nut - MVAgusta.net
post #1 of 13 (permalink) Old 08-23-2019, 02:58 PM Thread Starter
Submariner's Avatar
Dear All,
The slot on the top yoke nut on my F4 2000 model is annoyingly unaligned with the top yoke. The top yoke was previously replaced by my local MV dealer.
Whilst some may consider this a giggle, I want to adjust it to ensure alignment in what is a focal point of the bike.
I would appreciate any hints and tips on how to make such an aligment (such as any 'pinch bolts) which may need slackening.
https://www.ebay.com/itm/MV-Agusta-F...-/372409424324
I have purchased a pronged tool which locates very snuggly into the holes on the top yoke nut.
Many thanks
Sub
Submariner is offline
post #2 of 13 (permalink) Old 08-23-2019, 02:59 PM Thread Starter
Submariner's Avatar
The pronged tool has a 1/2" drive
post #3 of 13 (permalink) Old 08-23-2019, 03:57 PM
That slot is not for aesthetics...the steering bearings are adjusted with that fastener. When adjusted properly the slot is where it is. Moving it to make it align with the yoke will result in improper bearing adjustment.
post #4 of 13 (permalink) Old 08-23-2019, 04:00 PM Thread Starter
Submariner's Avatar
Thanks esq, so I bet you are suggesting that turning that nut a zillionith of a degree clockwise (which I assume is tighter) would not be a good thing? Ive attached a photo above to show the existing position
post #5 of 13 (permalink) Old 08-23-2019, 04:04 PM
Loosen the pinch bolt and give it a twist. Swing the forks side to side (preferably with the front of the bike suspended off the ground somehow). Smooth and no binding or excessive force required? Good to go.
Mine are no where near aligned at all...each bike is different.
post #6 of 13 (permalink) Old 08-23-2019, 04:04 PM
Glenno's Avatar
Ha Ha, It has always bothered me too.
2000 F4 750
Glenno is offline
post #7 of 13 (permalink) Old 08-23-2019, 04:59 PM Thread Starter
Submariner's Avatar
when u say the pinch bolt are u referring to the top yoke nut (the unaligned one) or the bolt on the underside of the yoke which I am pointing to in the photo below. I assume the latter
post #8 of 13 (permalink) Old 08-23-2019, 05:02 PM Thread Starter
Submariner's Avatar
photo added
post #9 of 13 (permalink) Old 08-23-2019, 11:11 PM
Yes..that one, the pinch bolt on the yoke.
post #10 of 13 (permalink) Old 08-24-2019, 06:03 AM Thread Starter
Submariner's Avatar
Thanks gents, it was unbelievably easy!!!
