2007 F4 1+1 electrical problem - MVAgusta.net
 4Likes
post #1 of 18 (permalink) Old 07-10-2019, 12:18 PM Thread Starter
Rabid dog's Avatar
Hi all
I've just fitted a new battery to the bike ( yes it is the right way round ). Any way, when I put the key in the ignition the dash lights up and rev counter sweeps and neutral light is on. Well, after the self test the neutral light goes out, I have no indicators, the driving lights are on but no switching between main beam and dipped lights, no brake lights and nothing at the starter button.
On the plus side the fuel pump primes, the horn works and the fan manual override works.
Any of you helpful people have any suggestions where to start.
Thanks in advance.
F4 1000R 1+1 2007
Rabid dog is offline
post #2 of 18 (permalink) Old 07-10-2019, 12:46 PM
First check your fuses.
The check that you got ALL of the wires connected othe correct terminals.
Then realize that the headlights only come on when the bike is running....
Then go through the troubleshooting section of the manual.
post #3 of 18 (permalink) Old 07-10-2019, 02:58 PM Thread Starter
Rabid dog's Avatar
Am I right in assuming that if the diode had blown I would have no dash either.
F4 1000R 1+1 2007
post #4 of 18 (permalink) Old 07-10-2019, 04:03 PM
No.
Please put your bike model and year in your signature line.
post #5 of 18 (permalink) Old 07-12-2019, 04:19 AM Thread Starter
Rabid dog's Avatar
Ok think I have got my signature sorted, not very good with internet type stuff, although I thought the title of the post might have given the game away.
nigelrb likes this.
F4 1000R 1+1 2007
post #6 of 18 (permalink) Old 07-12-2019, 06:46 AM
The title of the post goes away for reference after page one. Then it is a hunt to figure out which bike we are talking about and after several pages and other posters adding "well MY bike does this and this" then the OP's bike year and model is lost or hard to find.
AT 30 pages into a thread while troubleshooting it becomes and inconsiderate pain-in-the-ass.
Thank-you for sorting your signature line.
Now, where are we with your electrical issue?
post #7 of 18 (permalink) Old 07-12-2019, 07:40 AM Thread Starter
Rabid dog's Avatar
The latest development with my electrical problem has become somewhat more difficult to diagnose. I went to check what power I had going to various relays, fuses etc, but when I put the key in the bike and pushed the starter it fired into life. I still have no indicators and assume this is the flasher relay as the fuse is shared with other items, horn etc. I will post again if things get bad again, but thanks for your help.
F4 1000R 1+1 2007
post #8 of 18 (permalink) Old 07-12-2019, 07:52 AM
The INTERMITTENCY (Flasher Relay) is located on the left die of the bike in a cluster between the GENERAL REALY and the START SOLENOID.
Pull it, clean it's contacts, put it back.
While you are there, do the same to the other two relays.
Another possibility with the turn signals is that the nose contacts at the mirrors stalk bas in the electrical plate are misaligned or dirty.
Follow the procedure for nose removal EXACTLY and clean those contacts. Reinstall the nose with a turn signal actuated and only tighten the stalk base until the signal works...it is a very low torques value. Repeat for the other side.
post #9 of 18 (permalink) Old 07-12-2019, 12:02 PM Thread Starter
Rabid dog's Avatar
Went back out to the bike to check the indicator relay and now back to square one. I think it may have something to do with the alarm.
F4 1000R 1+1 2007
post #10 of 18 (permalink) Old 07-12-2019, 12:26 PM
FFS, here we go again....alarms cause issues with these bikes. Dump the f*cking thing...
There are probably 100 "My Alarm F*cked Up My Bike" threads in here.
theknurl and ceepee like this.
