This isnít right.. dash temperature - MVAgusta.net
 20Likes
post #1 of 44 (permalink) Old 07-02-2019, 10:35 PM Thread Starter
Blackfox's Avatar
She has been overheating(so it says). Ed has helped me so much(I’m surprised he hasn’t sent me to hell yet) and so have other members. I truly appreciate all the wise words from the ones that truly know MVs. I figured a water pump was going to do it, so I ordered. Now I know a microtec is a must, getting one ASAP. I just wanted to show you guys what I’m dealing with. All your inputs are more than welcome. I asked a question in a thread if anyone guys, when buying a used bike do you strip her down and check every inch. I feel as I need to do that.
My apologies for the shake at first.
Blackfox is offline
post #2 of 44 (permalink) Old 07-02-2019, 10:41 PM Thread Starter
Blackfox's Avatar
After it stayed at 235 blinking it dropped down to 212. Iím guessing cause the fans came on at 210..
Blackfox is offline
post #3 of 44 (permalink) Old 07-02-2019, 11:52 PM
Blackfox;
This another example of why we need you to put the year and model in your signature or under your avatar!!!!
If it's an '06 or before you can just buy a chip from Adam (merc07) single plug 1.6M ECU
If it's an '07-'09 it has a twin plug ECU 5SM......Chuck, has a friend that can reflash it and solve your problem
I'd bleed the radiator and test the temperature sensor 1st.......the temperature went up too fast
My Brutale 910R has a MicroTec, fans come on at 185įF and absolutely will not go over 186įF
post #4 of 44 (permalink) Old 07-03-2019, 12:12 AM Thread Starter
Blackfox's Avatar
Blackfox;
Youíre the man. I already decided that microtec is the way to go. Itís an 08 boss. Youíre right I need to update that. It has an rg3? And I also have the stock ecu. However Iím dealing with much more. Why I said I want to go over the whole bike and check every bolt. I have a bodis full system but I guess they installed it to close to the rear cowl.
Blackfox is offline
post #5 of 44 (permalink) Old 07-03-2019, 12:15 AM Thread Starter
Blackfox's Avatar
As the front light has a gap from the front fairings as well.
Blackfox is offline
post #6 of 44 (permalink) Old 07-03-2019, 07:06 AM
Man, the previous owner did not care for that bike!
An ECU change is not going to solve your issue. There is something else wrong there.
Either the system is not full of coolant, the temperature sensor is knackered, or your thermostat is not opening.
If your pressure cap were not working, you would see steam at those actual temperatures.
Pull the T-stat and see what happens. Make certain the system is full of coolant.
post #7 of 44 (permalink) Old 07-03-2019, 07:33 AM
That is way too fast for temps to go from basically cold to overheat.... Something fundamental is wrong. Thermostat stuck, radiator plugged up, air in system, faulty coolant temp sensor, water pump impeller not turning/broken......
I could not hear on the video...did the fans actually come on as temps went to 210? The ECU controls the fan based on the signal it receives...which is NOT the same signal the dash is using.
Like I said, that dual element sensor has been known to malfunction (on my bike and 2 others I personally know of). Dash temps reading much higher than actual. There is a test method for the sensor outlined in the manual.
silentservice703 likes this.
post #8 of 44 (permalink) Old 07-03-2019, 08:34 AM
Midnicrow's Avatar
My experience with over heating:
Steps to solve,,
1) Upgrade water pump to high flow impeller.
2) Swap plastic fans for aluminum Muzzy Fans.
3) Use engine ICE or other High Temp Coolant.
4) Get rid of bubbles in system by leaning bike over as you add coolant.
Fans generally come on at about 195 F.
No upgraded ECUs or anything like that on my bike, stock all the way.
Blackfox likes this.
James M.
Midnicrow is offline
post #9 of 44 (permalink) Old 07-03-2019, 09:20 AM
Al-
Al-'s Avatar
On top of what everyone else is saying, based on what I'm seeing on your exhaust you are running a higher than normal exhaust gas temp based on your stock ecu and full exhaust. Your bike will run lean with more airflow and the standard amount of fuel, and the stock ecu has advanced timing in certain areas to keep heat into the now missing catalytic converter. This also puts additional heat into the entire system. I've recently melted some of my bodywork with a similar setup.
2006 Brutale 910S
2012 F4 RR
2012 F4 RR
Al- is offline
post #10 of 44 (permalink) Old 07-03-2019, 10:27 AM
Tuning the ignition tables and setting A/F ratio to 13.4/1 will do immense good...but it won't solve THAT issue.
