Lower fan motor pre-2010 - MVAgusta.net
post #1 of 10 (permalink) Old 06-10-2019, 07:54 AM Thread Starter
Midnicrow's Avatar
Well I have done some searching of the forum to no avail.
Putting together my bike I noticed that the lower radiator fan’s blades are hard to turn. My Dad and I connected the motor to a 12 V battery and the motor has a hard time getting going. The top radiator fan motor moves smoothly.
Does anyone have or know of a source for the Panasonic motor that drives the fan? Star Twin has the unit for a mere 312 Euros.
My unit has muzzy fan blades, I just need a motor or reasonable facsimile.
Thanks for all your help!
PS Why are the part numbers on the upper radiator fan motor and the lower fan motor different? Do they draw different amps?
James M.
Midnicrow is offline
post #2 of 10 (permalink) Old 06-10-2019, 08:26 AM
James, what year and model is you MV?
post #3 of 10 (permalink) Old 06-10-2019, 08:47 AM Thread Starter
Midnicrow's Avatar
Hi!
F4 312 RR 1078 2009
James M.
post #4 of 10 (permalink) Old 06-10-2019, 09:01 AM
Originally Posted by Midnicrow View Post
Hi!
F4 312 RR 1078 2009
Would you please put that in your signature line?
post #5 of 10 (permalink) Old 06-10-2019, 09:05 AM
Here is a link to an EBAY upper fan. I believe the difference in part numbers is about the way the upper and lower fans mount.
You can scavenge the fan motor and install in your unit with the Muzzy Blade.
https://www.ebay.com/itm/Mv-Agusta-F...YAAOSwAnhbDpBI
post #6 of 10 (permalink) Old 06-10-2019, 09:17 AM Thread Starter
Midnicrow's Avatar
Cool thanks, If that's the case then Hopefully an easy fix! Let me not jinx this!
Will do!
James M.
post #7 of 10 (permalink) Old 06-10-2019, 09:29 AM
It should be a very easy fix.
post #8 of 10 (permalink) Old 06-17-2019, 01:46 PM
gotojoe's Avatar
If you have difficulty, Ill almost certainly have one.
Don't go the expensive route on it. !
email me on [email protected]
if you need help.
Joe
gotojoe is offline
The Following User Says Thank You to gotojoe For This Useful Post:
post #9 of 10 (permalink) Old 06-17-2019, 07:08 PM
R1andrew's Avatar
I also have one, but you will need to connect the wires back on. I used them to keep the stock connection when I added my lighter fans. You have about 3/4 inch of the wire to use. Mine are from my 07 F4R, but I would l think they were the same.
MV Agusta F4 Superleggera (Mona Lisa)
MV Agusta F3 Ago 2015
MV Agusta F4 1000 Senna #25
Ducati 1098 2009
R1andrew is offline
The Following User Says Thank You to R1andrew For This Useful Post:
post #10 of 10 (permalink) Old 06-18-2019, 06:38 AM Thread Starter
Midnicrow's Avatar
Thanks guys! Got one on Ebay for about 65 US with shipping. I definitely travel the long less expensive route! Expensive in man hours, yet have earned a lot of knowledge. Work in progress will post pics once arrived!
James M.
