F4 1000 Randomly Rough Idle - MVAgusta.net
 4Likes
post #1 of 32 (permalink) Old 05-07-2019, 12:58 PM Thread Starter
ddn
I just bought a 2007 F4 1000 R in overall great condition with about 16k miles. It goes like a Falcon 9, which you all of course know. The only issue I'm having is that it will fairly regularly idle rough, when it's not idling perfectly. Regardless of cold or hot, I'll start it up or come to a stop, it'll settle into an idle right around 1200 indicated and idle nicely for a bit and then suddenly start missing and idling up to about 2k. Sometimes it'll stop, sometimes it'll die. If I'm at a light I'll flick the throttle a little and this usually smooths it out enough. I've run a couple tanks of non-ethanol gas through it just to see if that would clear out any old fuel.
I've got the parts to do the fuel filter & fuel line mods & replacement, as well as new plugs. Before I take things apart though I wanted to ask if there is anything else I should be checking while I'm there and have it all apart? As I'm close to the 18k service, I'll probably check the valves while I'm there. I have not reset the TPS.
Also have the appropriate cables to run the diagnostic software, but haven't gotten my hands on it yet.
ddn is offline
post #2 of 32 (permalink) Old 05-07-2019, 02:05 PM
You are running down the right path.
post #3 of 32 (permalink) Old 05-07-2019, 02:23 PM
ViggenF4's Avatar
I would also balance the TB:s, and check the mixture.
ViggenF4 is offline
post #4 of 32 (permalink) Old 05-07-2019, 03:10 PM
Could it be the infamous EBS relay? or was that eliminated on the Euro3 bikes?
I suspect your routine maintenance, and especially the new plugs will take care of it. Putting in Iridiums ??
post #5 of 32 (permalink) Old 05-07-2019, 05:47 PM
MVAgusta.net Sponsor
mitchy's Avatar
You could also have a faulty ignition coil.
Look for cracks on the coil stems when you do the plugs.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
post #6 of 32 (permalink) Old 05-07-2019, 06:01 PM Thread Starter
ddn
I was just going to run NGK CR9EB's.
The TBs I can balance. How do I check the mixture?
ddn is offline
post #7 of 32 (permalink) Old 05-07-2019, 09:09 PM
The CR9EI plugs make a big difference....
mitchy likes this.
post #8 of 32 (permalink) Old 05-08-2019, 05:47 AM
ViggenF4's Avatar
I had to lean out mine from the factory setting to make it run 100%. Im running the 9EB cos the iridiums quit after 800km. Could have been just random fail though.
ViggenF4 is offline
post #9 of 32 (permalink) Old 05-08-2019, 10:24 AM Thread Starter
ddn
I'm not sure but from reading other EBS threads the symptoms sound familiar. I'll take a look at that and the coil packs while I'm there.
ddn is offline
post #10 of 32 (permalink) Old 05-08-2019, 12:23 PM
No EBS relay on the 312R
Vacuum hose leaks are a possibility though.
Who did your tuning? The 312R (and all MVs for that matter) are quite lean from the factory.....
