750 clutch cover gasket - MVAgusta.net
post #1 of 3 (permalink) Old 05-05-2019, 01:37 PM Thread Starter
Bexar80's Avatar
Is the 750's clutch cover gasket just flat paper material? I haven't taken mine off yet, but I'm mulling over the cost of $50+ vs. making my own from gasket paper. Not to sound cheap but it's easy to make unless the original has a molded grove or ridge.
-Benjamin-
2004 Brutale 750S
Bexar80 is offline
post #2 of 3 (permalink) Old 05-05-2019, 06:22 PM
Skip the gasket......
I use good old Permatex High Temp Form-a-Gasket , get the orange or red, easier to see when doing clean-up
Clean the surfaces with lacquer thinner or acetone......
USE A VERY THIN COAT!!!
You might be able to reuse the gasket.....be careful of the wiring harness on the lower left of the cover
post #3 of 3 (permalink) Old 05-07-2019, 01:32 AM
ViggenF4's Avatar
Im also running without gasket, just used hondabond. But you can use any good product for the same result.
ViggenF4 is offline
