Brutale 1078 full loss of Electrics - MVAgusta.net
 2Likes
  • 1 Post By silentservice703
  • 1 Post By Deano
post #1 of 9 (permalink) Old 04-30-2019, 01:40 PM Thread Starter
SAROY's Avatar
Overtaking at High Speed today and full loss of electrics, dash & engine
pulled in clutch and cruised to a safe place to stop.
Removed seats and visual check of electrics, all seemed fine. Disconnected starter solenoid & checked starter solenoid fuses, the spare one was fine
the main 40 amp one was blown.
replaced blown fuse and with ignition key in OFF position, power came back to the dash.
Started bike and rode home.
parked up and turned OFF ignition, engine kept running and dash still lit up.
Stopped engine using kill switch
Dash still lit up
Had to Disconnect starter solenoid to switch off power.
All lights, indicators etc work when engine is running.
any pointers guys? anyone had this before?
Does anyone in UK have a set of RG3 exhausts for a 2006 F4 1000R (for sale).
SAROY is offline
post #2 of 9 (permalink) Old 04-30-2019, 01:52 PM
To me this sounds like a failure of the SPU...where the fuses live...
What was the last maintenance done to the bike prior to failure?
post #3 of 9 (permalink) Old 04-30-2019, 02:06 PM Thread Starter
SAROY's Avatar
It had a full service done 2 months ago and a Scorpion/Datatool tracker fitted,
also heated grips.
bike has done 1200 miles since then and no problem until this afternoon
With the SPU failure would the bike still run? but cause spurious faults such as power on when ignition in off position etc
.https://www.mvagusta.net/forum/13-br...u-resolve.html
SAROY is offline
post #4 of 9 (permalink) Old 04-30-2019, 02:16 PM
Well, there are well documented problems with datatool devices and heated grips add extra load to the system.
Either way, I'd be looking at the SPU.
theknurl likes this.
post #5 of 9 (permalink) Old 05-02-2019, 02:20 PM Thread Starter
SAROY's Avatar
Removed tank and checked all wiring & loom, connected all back up, replaced fuses and everything was back to normal.
Ignition working again, dash - all as new, fault seems to have fixed.
I suspect as silentservice has suggested the SPU is on the way out, and all is back as "appears normal" due to being sat for a day and cooled down. Next dry day I will take out again for a good run and see what happens at high temp running, once the SPU heats up again, possibly simillar problem will occur.
Is there a way to test the SPU; diagnostics? or is it a matter of accepting and changing out
SAROY is offline
post #6 of 9 (permalink) Old 05-02-2019, 07:03 PM
cruiser's Avatar
FYI
https://www.mvagusta.net/forum/20-ma...u-service.html
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is online now
post #7 of 9 (permalink) Old 05-13-2019, 03:30 AM Thread Starter
SAROY's Avatar
Fault found and rectified; so glad I dug deeper rather than replace the SPU as I would have been 400 out of pocket, sometimes its best to take a slower more detailed look and inspection.
Bike back up and running.
SAROY is offline
post #8 of 9 (permalink) Old 05-13-2019, 03:56 AM
Deano's Avatar
So what was the fault?
nigelrb likes this.
2009 1078RR Brutale
Deano is offline
post #9 of 9 (permalink) Old 05-13-2019, 02:14 PM Thread Starter
SAROY's Avatar
Although I thought I fully checked the wiring loom, I went over this once again and found it had been rubbing on right hand side of bike frame and a couple of wires earthing on frame, patched everything back up and all is good.
SAROY is offline
