Engine identification - MVAgusta.net
post #1 of 5 (permalink) Old 04-28-2019, 12:17 PM Thread Starter
nonam3k's Avatar
Hallo. Can someone write me from which version of the motorcycle is this engine?
f4 1000s or f4 1000r ?
Buggy Road Legal - Engine MV Agusta 1000R
nonam3k is offline
post #2 of 5 (permalink) Old 04-28-2019, 04:21 PM
dansoarr's Avatar
looks like a 2009 1078RR Brutale based on the ECU data.
8000A6403 was replaced by 8C00B1322, I think. A bit or research should tell you. Some one with more Gen 1 knowledge will be able to confirm.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #3 of 5 (permalink) Old 04-28-2019, 04:45 PM
The ECU is labeled as a F41000S. The cylinder head cover does not have the second air system, so a pre-Euro3 model.
That makes it 2007 or earlier in the USA, maybe 2006 and earlier in other markets.
The F4 1000S and R engines are pretty much the same, it was the chassis upgrades that made the "R".
post #4 of 5 (permalink) Old 04-28-2019, 05:06 PM Thread Starter
nonam3k's Avatar
Yes ECU date is 2006-10-14 . Are these engines mechanically the same?
nonam3k is offline
post #5 of 5 (permalink) Old 04-29-2019, 06:52 AM
I do believe so.... if not, the only difference might be the cams or throttle body size (don't think so). Easily confirmed by comparing part numbers.
Someone correct me if I am wrong.
