First things first...that line does not appear to be the correct J30R10 immersible line. It should have a fabric reinforcement layered in and J30R10 stamped on the line.
As for the fuel pump: it should run for 3 seconds when attached to the loom and at KEY ON. IF it simply buzzes when 12 vdc is directly applied, then it is time for a new pump.
There is no pressure switch in the fuel system. There is a 3 atm pressure regulator in the return line at the pump plate.
