2013 1090 RR rear pad replacement how to - MVAgusta.net
 3Likes
  • 1 Post By silentservice703
  • 1 Post By theknurl
post #1 of 9 (permalink) Old 03-18-2019, 07:02 AM Thread Starter
tonymopar440's Avatar
Tried to search shop manual on what the best process is to replace rear brake pads on 1090RR. It advised to remove rear wheel. is it possible to change pads without removing the rear wheel?
tonymopar440 is offline
post #2 of 9 (permalink) Old 03-18-2019, 07:20 AM
The rear wheel is removed in order to facilitate easier access to the components.
The pin that holds the pads in place is removed from the left side of the bike.
If you feel like working in and encumbered space and you have good dexterity, then you should be able to replace the pads without removing the rear wheel.
That being said: why wouldn't you remove the rear wheel and do a clean and inspect of the components back there?
tonymopar440 likes this.
post #3 of 9 (permalink) Old 03-19-2019, 11:12 AM Thread Starter
what socket would I need to remove the wheel?
post #4 of 9 (permalink) Old 03-19-2019, 12:53 PM
This one:
https://motowheels.com/i-19762929-sp...SABEgLme_D_BwE
post #5 of 9 (permalink) Old 03-19-2019, 04:31 PM
tonymopar440;
Sooner or later you'll need to replace the back tire..... and need the special
socket
Get the one Chuck recommended Speedymoto #04-0203
But buy it directly from Speedymoto..... mention this Forum and they'll give you a discount
post #6 of 9 (permalink) Old 03-21-2019, 01:15 PM Thread Starter
tonymopar440;
socket
Thanks, I also heard from a dealer that a standard 55mm socket will work as well.
post #7 of 9 (permalink) Old 03-21-2019, 01:29 PM
Feel free to use a standard socket...but be prepared to mar your wheel nut. There is a two degree taper on the nut and on the Speedy Moto Socket.
Of course, vice grips, channel locks, a welding torch, a die grinder will also all remove your wheel nut.
theknurl likes this.
post #8 of 9 (permalink) Old 03-21-2019, 07:10 PM
Thumbs down ?
Hummmm;
Fuck the dealer, he's an idiot.......
There's a sticky about tapered 55mm sockets
https://www.mvagusta.net/forum/153-g...mm-socket.html
post #9 of 9 (permalink) Old 03-22-2019, 11:03 AM
Hey, Chuck, You forgot punches and pipe wrenches
silentservice703 likes this.
