Brutale 910R engine overhaul advice - MVAgusta.net
 3Likes
  • 1 Post By ViggenF4
  • 1 Post By rsawkins
  • 1 Post By phunkinit
post #1 of 10 (permalink) Old 03-09-2019, 02:45 AM Thread Starter
Hello,
Some time ago I've posted a thread with topic 'Brutale 910R engine exploded.'
https://www.mvagusta.net/forum/20-ma...-exploded.html
Time has not been on my side, but now I took some time to drop the engine and remove the head.
Cil 2, 3 and 4 are [email protected]
Timing chain missed a tooth, because of low tension.
I assume Cilinders need to be bored and need honing (not sure if this is correct english ) + 3 new complete piston sets.
Knowing this is going to be a lot of $$ is making me wonder if it is all worth it ?
Somebody any wise words ? How much $$ will this set me back ? Are there cheaper alternatives than the OEM pistons ?
Thanks guys
Brutale 910R 2007
phunkinit is offline
post #2 of 10 (permalink) Old 03-09-2019, 05:46 AM
@phunkinit: We implore folks to put their location in their profile so that local (relatively) people can provide more accurate input.
Please do this through TOOLS>USER CP> EDIT DETAILS
You can also put your bike model in your signature line so that, as this thread grows, we can readily identify the model and year.
Not knowing where you are on this big blue marble limits the information accuracy. Things are more expensive in California than they are in Cambodia.
As for yuor issue, yes, I would be doing a complete teardown and rebuild including cylinder honing. Gaskets may be your toughest part to find.
'07 Ducati Monster S4Rs ("Slightly" modded...), '07 Ducati Monster 695
silentservice703 is online now
post #3 of 10 (permalink) Old 03-09-2019, 09:06 AM Thread Starter
Done !
It's right there where it is always was...
yes, thank you
Brutale 910R 2007
post #4 of 10 (permalink) Old 03-09-2019, 09:16 AM
Originally Posted by phunkinit View Post
Done !
Thanks and sorry I missed that! I wish you luck in your rebuild.
post #5 of 10 (permalink) Old 03-10-2019, 01:05 AM
Id say buy a complete used engine for much less than the rebuild is gona cost. Lots of 910 R engines around in Europe!!
And get a manual CCT
anothermvfanatic likes this.
ViggenF4 is offline
The Following User Says Thank You to ViggenF4 For This Useful Post:
post #6 of 10 (permalink) Old 03-10-2019, 04:21 AM
When I priced rebuilding my 750 with snapped cam chain it was cheaper to buy a whole new bike. I'd look at a used engine, should be plenty of 910R motors in Europe.
Rich
rsawkins is offline
The Following User Says Thank You to rsawkins For This Useful Post:
post #7 of 10 (permalink) Old 03-10-2019, 08:47 AM Thread Starter
Manual CCT from Tokymods in the mail few a days ago.... Learned my lesson the hard way.
Strange thing is that im having a hard time finding a 910 R engine.
1 for sale in Texas US and 1 in Italy, but engine is different because of EURO3, ....thats it for now.
The S engines are easier to find.
Does anybody know more about the differences between R and S ?
- Suspension spring charasteristics front fork
- rear shock with rebound compression high speed and spring preload (also on some S editions )
- Radial Brembo brake callipers front and back
- light weight magnesium wheels,
- Stock rear tire 190 on R v 180 on S
- some goodies like a bellypan (depending on version)
- other camshafts for more agressive throttle response
- Valve cover in red color
- in case of racing exhaust +5 hp, overall more power but ONLY in case of euro 2
- higher pricing
- Limited Editons (Wally/starfighter,...
- More colour options
What issues could arise swapping the R for an S engine ?
A smoother run ?
Mapping ECU / EEPROM compability / sensors / reduced power / ECU going bananas because of unexpected parameters / ....?
For now, I have no reason to believe that is the case.
Brutale 910R 2007
post #8 of 10 (permalink) Old 03-11-2019, 09:11 AM Thread Starter
On a side note; honing Nikasil cylinder walls would destroy them. (plenty of reading on the www)
Deglazing would be possible, but is merely for cleaning and getting a smoother surface and not for damage like in th pics above.
Please correct me if i'm wrong, maybe somebody will use this information...
Brutale 910R 2007
post #9 of 10 (permalink) Old 03-11-2019, 09:26 AM
The cylinder walls are damaged. You could repair the cylinder (weld in the dents, bore to size and re-plating by a specialist), other wise you must replace. The 910S engine is a slip-in replacement. Most of the "R" upgrades are chassis.
The difference between Euro 2 and Euro 3 are mostly electrical. The second air system is the only significant mechanical change...and that could be ignored with proper ECU tuning.
Euro 2 used the 1.6M ECU....Euro 3 uses 5SM ECU, lambda sensor in exhaust, second air system, and single Engine Coolant Sensor with 2 circuits incorporated (Euro 2 used 2 separate senors).
Good luck with the repair.
'08 910R (Gina), '04 F4 SPR #275 Track Bike (Lola), YSR50 (The Rabbit) restoration project, '71 CB100 (Lil' Red), '75 RD350C (Orange Bird) restoration project, '08 TT-R110 (Buster) Pam's ride, 2015 Indian Chieftain (Rita) my "low-n-slow", '70 Suzuki F50 (Baby Blue), 2018 Suzuki GSX-S750L8 (Susie Q)
post #10 of 10 (permalink) Old 03-11-2019, 12:33 PM Thread Starter
thank you for the input, fixing the cilinderhead costs 1200 euro's....
So it's a no brainer, i'm going for the engine swap
Found an euro2 R engine with 8K miles, with warranty and compression tested. Should arrive next week.
I did some homework, and filled in the gaps with the differences between R and S (disregarding ECU and euro/2/3)
esq'z me likes this.
Brutale 910R 2007
