Raise idle speed on brutale 1090 - MVAgusta.net
 2Likes
  • 1 Post By esq'z me
  • 1 Post By silentservice703
post #1 of 6 (permalink) Old 02-07-2019, 09:59 AM Thread Starter
tonymopar440's Avatar
How do you adjust the idle speed to raise it a few hundred rpm?
tonymopar440 is offline
post #2 of 6 (permalink) Old 02-07-2019, 12:12 PM
Done with fuel and ignition mapping....or opening the air bleed screws on the throttle bodies, but then you will still need fuel adjustment.
That's the correct way. The cheater way (not recommended by the factory) is to advance the stop screw on the cable pulley (marked with yellow "don't touch this" paint). But then you will need to reset the TPS.
That method only works on cable operated throttle. Ride-by-wire can not be changed without ECU mods.
tonymopar440 likes this.
post #3 of 6 (permalink) Old 02-07-2019, 12:13 PM
Generally, you get the diagnostic software and the proprietary license and adjust it there.
What year is your 1090? What model is your 1090? In what country is your 1090?
esq'z me likes this.
post #4 of 6 (permalink) Old 02-08-2019, 06:32 AM Thread Starter
it's a 2013
post #5 of 6 (permalink) Old 02-08-2019, 06:43 AM
According to the Workshop Manual, your bike has the Magneti Marelli 5SM ECU.
That being said, VDST software is required to adjust idle settings.
Small adjustments can be made to idle speed by adjusting the ferrules on the throttle supply and return cables. Taking out the slop, and making sure your throttle advance lever (choke) is working properly.
post #6 of 6 (permalink) Old 02-08-2019, 09:46 AM
If you have the 5SM and throttle cables then adjusting the central stop screw on the pulley will raise idle speed....but you WILL have to reset the TPS with the VDST software.
OR, you can install a Microtec 226 (I have one for sale) and set the idle speed by adjusting ignition and fueling....as demonstrated in a video supplied by Chris at X-Bikes. The only "proper" way to adjust idles speed.
