Cam missing one tooth??? - MVAgusta.net
 5Likes
post #1 of 11 (permalink) Old 01-21-2019, 05:42 AM Thread Starter
ManiacDray's Avatar
Hi all
Bike is at workshop and mechanic tells me there is one tooth missing??? Not an MV Mechanic so he is baffled as well.
2012 MV Agusta Brutale 920. He checked the manual and according to that, its missing one tooth? Is this normal?
Not sure if its needs to be replaced or kept as is, Check pics
ManiacDray is offline
post #2 of 11 (permalink) Old 01-21-2019, 06:04 AM
No it is not !!! That is the "phonic wheel" or crank position sensor trigger. It is technically a "reluctor" and when the gap passes the sensor the signal is generated to the ECU.
I would be very suspicious of this "mechanic's" skills if he doesn't understand that.
Where on this planet are you located? Please add that to your profile.
post #3 of 11 (permalink) Old 01-21-2019, 06:24 AM Thread Starter
ManiacDray's Avatar
My apologies, I'm located in South Africa and unfortunately MV has pulled out. All dealerships closed down and mechanics I know of has relocated.
Once again I apologize. I'm not too bright with these things lol. He says lining everything up on the cam and crack shaft shows that there is one tooth missing? Not sure if this makes sense? He has followed the manual accordingly.
The mechanic is brilliant, but this is the first time for him seeing this. There is no slack in chain and everything else inside is good. Just this one missing tooth when lining up it catching us off guard.
post #4 of 11 (permalink) Old 01-21-2019, 06:47 AM
Here is an image from the engine manuals that show the alignment. If your mechanic doesn't understand the gap in the phonic wheel,then find another one.
Is it possible you didn't understand the terms he was using and to what "tooth" hes was referring?
What you pictured is at the bottom of this image...it is not a CAM. The engine could be out of time if one of the cams (at the top of the image), or the shaft (at the bottom of the image) "SKIPPED" a tooth.
post #5 of 11 (permalink) Old 01-21-2019, 07:17 AM Thread Starter
ManiacDray's Avatar
Okay so this is how he said I should explain.
When you set you crank shaft mark, the scribe lines on top of the cam shaft is not flush with the cylinder head on the intake. But the pins in between are correct. Its like it seems that the cams are slightly turned forward almost by 1 tooth.
And if you line up the scribe marks on top of the cam shaft with the cylinder head, the scribe line on crank shaft is slightly lower than where it should be. Like he says almost 1 tooth.
I hope this explains it better, I suck at this haha.
post #6 of 11 (permalink) Old 01-21-2019, 09:20 AM
What you are describing is cam shafts that are not timed correctly. He will need to remove the cam chain tensioner and re-time the cams.
It is probable that someone adjusted a valve clearance and missed the cam timing when they put it back together.... or pulled the tensioner to replace and didn't notice the chain "jumped" a tooth in the process. Easy to do.
The bike will not run properly with the cam timing advanced.
Now .... IF the intake cam mark is level with the gasket surface, the pin count is correct, and the exhaust cam mark is below horizontal...then you have a cam chain that is stretched and needs to be replaced.
Question? how many miles/kilometers on your bike? Show the drawing SS703 provided to your mechanic. That should help him decide what to do if he is indeed any good.
And do please add your locale to your profile.
post #7 of 11 (permalink) Old 01-21-2019, 01:21 PM
hokums's Avatar
If you search the forum, you’ll find this is common to a number of bikes, including mine......it will run fine.....it’s just one of those ‘Italian’ things.
ManiacDray likes this.
2010 F4 1000S
hokums is offline
The Following User Says Thank You to hokums For This Useful Post:
post #8 of 11 (permalink) Old 01-21-2019, 01:52 PM
It may run "fine" but it may not be performing as it should. The timing marks are there with a purpose. If they are not aligned correctly then something is wrong.
It can be a real PIA to get the cams timed correctly. R1andrew and I had to go through the process several times on Mona Lisa before it cam out right....but it did come out right.
R1andrew, ManiacDray and nigelrb like this.
post #9 of 11 (permalink) Old 01-21-2019, 01:57 PM
Bumpkin's Avatar
Check that your mechanic is turning the crank the right way too, cranks on these bikes run in the opposite direction to most other bikes. Turning the wrong way may give the impression of the slight timing errors he's seeing. Show him the illustration that silentservice703 posted, the chain run at the back needs to be under tension with the tensioner towards the front of the bike taking up the slack. From the side as show crank direction is clockwise.
esq'z me likes this.
Chas
Bumpkin is offline
post #10 of 11 (permalink) Old 01-21-2019, 05:38 PM
Tony F's Avatar
From the post above I take it that with the crank mark lined up correctly the exhaust cam times correctly but the intake is out by almost one tooth. Is that correct?
Also as above, it would be helpful to know the distance the bike has travelled.
My F4RR had a camchain replaced under warranty some time ago and I recall the dealer saying the cam timing marks didn't fully line up on reassembly. There was a half tooth difference but I cant remember if it was on one or both camshafts. After consultation with the factory it was timed so that any wear or stretch in the chain moved the timing to the correct position. So differences do arise.
Tony F is offline
