F4 750 not firing - MVAgusta.net
 4Likes
post #1 of 21 (permalink) Old 01-12-2019, 06:17 AM Thread Starter
Le Danoir's Avatar
F4 750 not firing
I've replaced the cam chain tensioner so the rad's and exhaust are/is off and I just wanted to quickly fire it up to check for noises.
So I've just got the tank and airbox fitted (2 fuel lines and fuel pump plug).
Turns over find, plenty of fuel, the fuel pump primes but it just won't fire up.
Am I missing something?...... the alarm confuses the hell out of me, could that be enabled?
Le Danoir is offline
post #2 of 21 (permalink) Old 01-12-2019, 07:14 AM
Scant information to go on, but I would check the fuel pump discharge hose in the tank first.
How far did you disassemble?
Did you disconnect and reconnect the battery?
post #3 of 21 (permalink) Old 01-12-2019, 07:15 AM
There have also been issues with the fuel line quick disconnects not quite being clicked all the way together.
post #4 of 21 (permalink) Old 01-12-2019, 07:34 AM Thread Starter
Le Danoir's Avatar
Bike has been stood for probably a couple of years.
Fresh fuel and I can clearly see the injectors firing with the airbox off.
Typically I can't get my plug socket down the hole as the rubber gaskets are protruding. I'll bob out and try and find a slender socket or I'll trim the gaskets but in the meantime I'm assuming no spark as there's plenty of fuel.
Presumably the ECU won't require signals from the temp sensor on the rad to fire?....... As I've got all of that disconnected.
post #5 of 21 (permalink) Old 01-12-2019, 07:38 AM Thread Starter
Le Danoir's Avatar
As far as disassembling, it's been down to pretty much engine and frame while I did some cosmetic jobs........
post #6 of 21 (permalink) Old 01-12-2019, 07:51 AM
Then you are right to check. or replace plugs...But, since you have had it disassembled, check that you connected the battery with correct polarity and that you actually connected all wires in the correct locations.
post #7 of 21 (permalink) Old 01-12-2019, 07:52 AM
...and please put the bike year and model in your signature line. As this thread reaches page two, it will be helpful.
post #8 of 21 (permalink) Old 01-12-2019, 08:52 AM Thread Starter
Le Danoir's Avatar
So this is where Iím up to.
I connected the temp sensor just in case the ECU needed a signal to fire.
MV Agusta F4 750 (MY99)
post #9 of 21 (permalink) Old 01-12-2019, 09:33 AM
What are you using as a troubleshooting guide?
Have you checked the latch and power relays?
The water temperature sensor, while it feeds the ECU a signal that compensates duration of injection, will not prevent spark from occurring.
The manual has a great troubleshooting section.
post #10 of 21 (permalink) Old 01-12-2019, 02:01 PM Thread Starter
Le Danoir's Avatar
OK so now I'm concerned that my timing chain has slipped.
I've taken the valve cover and the crank timing cover off and lined the mark up with the engine casing. Apparently marks on the toothed parts of the cams should line up....... the only marks I can see are about 90 degrees apart!!
There was no mechanical noise and the engine is turning freely.......
erm....... HELP!!
