Engine 'click' when trying to start - MVAgusta.net
 4Likes
LinkBack Thread Tools
Old 12-02-2018, 09:54 AM Thread Starter
Le Danoir's Avatar
Chaps
Early F4 750, 20K miles. I've had it about 4 years, ridden once at a charity track event but it stands looking pretty on a pedestal in my garage mostly.
I've been doing some cosmetic refurb work on it, replacing weathered fasteners etc and decided to run it up to temp to change the oil etc and all I got was a 'click' noise....... thing is, it sounds like it's coming from the front of the engine and the engine is trying to turn.
I'm wondering if something to do with the cam chain tensioner could be stopping the engine from turning and how I find out?
Advice greatly appreciated.
Dan
Le Danoir is offline
Old 12-02-2018, 09:56 AM
It's your battery.
Old 12-02-2018, 09:58 AM
Dan, there are many threads about this within this forum. It is probably a weak battery and corroded or loose electrical connections in the start circuit.
Charge or replace the battery...better yet, load test it.
Do not install the battery with reverse polarity....easy to do if you aren't paying attention.
What is the last thing done to the bike before this start attempt?
Do you keep the bike on a smart charger?
Old 12-02-2018, 10:19 AM Thread Starter
Le Danoir's Avatar
Sorry, should have added, battery is new and fully charged.
I will do a load test to be sure, thanks
Old 12-02-2018, 10:39 AM
Ok, this concerns me.
Did you install the new battery wit the Negative (-) terminal toward the front of the bike?
Did you install ALL of the wires to the correct terminals?
Old 12-02-2018, 11:26 AM Thread Starter
Le Danoir's Avatar
All connected tickety boo....... now, hereís a strange one.....
Just bombed out to check the connections and the blighter only turned over ...... didnít have the fuel tank on so it didnít fire up.
Stopped, tried again...... click
Old 12-02-2018, 11:31 AM
Check your connections at the start solenoid.
This is a known issue with these bikes. Left side. Literally disconnect the wires, clean and reterm.
Old 12-03-2018, 07:21 AM Thread Starter
Le Danoir's Avatar
No joy...... removed and cleaned all the connectors, it's making an audible click but nothing.
They appear to be fairly cheap, so I'll order one unless I should be checking something else?
Old 12-03-2018, 07:39 AM
Have you checked the voltage at your terminals and at the starter solenoid under load?
Please put your bike year and model in your signature as this help us help you without having to dig to figure out what bike is being diagnosed,.
Old 12-03-2018, 07:49 AM
Ok, please don't think I am doubting your capabilities; the number of people who have spent weeks of replacing parts and "diagnosing" issues only to find that "hey, there IS another wire there...maybe if I hook that up...." and bingo everything is good.
A reverse polarity situation, even for a nanosecond blows diodes in these bikes and then you have starting issues.
I am being particular about wiring here simply because it IS an issue that keeps cropping up. Burned out solenoids is NOT something that keeps cropping up.
Before I went out spending money, I would recheck my work and voltage test the system during the start sequence.
cruiser likes this.
