Weird! - MVAgusta.net
  • 1 Post By Deano
post #1 of 7 (permalink) Old 10-30-2018, 06:48 AM Thread Starter
Deano's Avatar
Weird!
Ladies,
Found the attached today after cleaning the bike for the first time literally in 3 months. Jammed between the water pump hose and the crankcase. It's a nut off a crankcase stud, right side inlet. They (studs) look pretty long so I wondered how it had come out. Checked the depth of the hole and it's only 30mm so it appears the stud is still in there. However the nut is clear and threads intact. So if it came loose and jumped off how come the top 40mm or so snapped off the stud. Weird.
Bike runs fine and it could've been like this for a long time. I always blow out the right side nuts with air after a wash. They're easier to see than the left which I've never noticed. Check yours.
If I see any leaks it looks like a motor rebuild.
Deano
2009 1078RR Brutale
Deano is online now
post #2 of 7 (permalink) Old 10-30-2018, 09:08 AM
EVO Chris's Avatar
that's scary, lets hope more don't let go. Is the head a clean break or can you see a dull area as if it had an early fracture?
MV F4 750 EVO3 2003
MV Brutale 910s 2007
Honda VFR800 1998
Honda MBX 125 FE 1983
F4 Agusta mini moto replica
EVO Chris is offline
post #3 of 7 (permalink) Old 10-30-2018, 04:32 PM Thread Starter
Deano's Avatar
Pretty awkward place to see into. I'll investigate with mirror and lights when I get the time and get back to you.
Deano
2009 1078RR Brutale
Deano is online now
post #4 of 7 (permalink) Old 10-30-2018, 10:04 PM
Deano;
Don't worry about unless the head is leaking......I'm not fixing mine
Upper stud found ~25,000mi
The much older broken stud found later, with no washer????
Head gasket doesn't leak.......fuck it
If you're lucky with a penetrant you might able to unscrew the stud, otherwise pull the head
In my case probably the cylinder too
post #5 of 7 (permalink) Old 10-31-2018, 12:09 AM Thread Starter
Deano's Avatar
Noel,
Thanks for that. Obviously not a one off then. Nothings leaking and it's running well so like you, fuck it, I'll leave it alone. Years ago an expert Norton mechanic told me you never touch the head on a Norton if it's not leaking so I'll use his advice and yours on the Brutale.
Cheers mate
Deano
theknurl likes this.
Deano is online now
post #6 of 7 (permalink) Old 10-31-2018, 02:28 AM
Deano;
Never seen a broken cylinder stud before and I've been building motors for 50+ years
Both were outside rear studs??? the right one jumped up on a large bump in the road
and stuck against the head
The 2nd one i spotted because.the washer was missing???? go figure
I bought it with 4,200mi on it
post #7 of 7 (permalink) Old 10-31-2018, 05:45 AM Thread Starter
Deano's Avatar
As I said, a weird thing to break you'd think. Bought mine at 4500km. Expecting the other side to go now. Some engineer fucked up the metallurgy there for sure.
Deano
2009 1078RR Brutale
Deano is online now
