2013 B4 1090R Engine Removal Stand - MVAgusta.net
 3Likes
post #1 of 21 (permalink) Old 10-25-2018, 06:11 AM Thread Starter
Pulse's Avatar
I need to remove the engine from my 2013 B4 1090R (South Africa), but do not have the required engine removal stand (8000B4417).
Is there perhaps someone that has one that can provide me with the dimensions, and some photos? I’ll fabricate one if need be. The service manual is also not very clear on where it should fit on the engine.
Can I support the engine on the flat part on the bottom next to drain plug/oil filter?
Anything I should be cautious with?
Pulse is offline
post #2 of 21 (permalink) Old 10-25-2018, 08:01 AM
hokums's Avatar
Iím using the same engine support for my 2010 F4. The frame Ďfitsí onto two bolt heads at the front of the engine and supports the oil sump at the rear. The engine only rests on the stand and isnít the most secure, if your working on it, hence the bungee straps in the picture to hold it in place.
Measurement wise:
The base is 385mm square using 30mm square tubing.
The frame sits 190mm off the ground to the top of the tube.
Front supports are 270mm in height and positioned 90mm from the front edge of the stand.
Rear support is 140mm in height with a threaded pad to allow height/tilt adjustment. The support is 180mm from the left side of the frame and 80mm from the rear. In the pictures you can see the 2nd cross brace which supports the rear stand.
Hopefully the pictures will help you make sense of the above.
hokums is offline
post #3 of 21 (permalink) Old 10-25-2018, 08:44 AM Thread Starter
Pulse's Avatar
Thank you hokums, that helps a lot. I’ll see what I can come up with over the weekend.
I need to get it onto a pallet to take to an engineering shop. There is a bolt that someone had snapped off and glued back on. I think this bike had a bit of a dodgy lofe before I got it. I need to have it sorted.
I’m going to have lots of fun getting this engine out and back in.
Pulse is offline
post #4 of 21 (permalink) Old 10-25-2018, 09:10 AM
You could just cobble together a stand from wood. More than a few have done this.
post #5 of 21 (permalink) Old 10-25-2018, 09:15 AM Thread Starter
Pulse's Avatar
Thank you. I’ll probably end up with something built directly onto a wooden pallet. Would it be okay to carry all the weight directly on the sump?
Any idea of the weight of the dry engine?
Pulse is offline
post #6 of 21 (permalink) Old 10-25-2018, 01:32 PM
hokums's Avatar
Two people can easily lift it. I think the stand comes into its own when refitting the engine.
Good luck👍
esq'z me likes this.
hokums is offline
post #7 of 21 (permalink) Old 10-25-2018, 05:15 PM
I think @R1andrew made a nice wood cradle for his engine while building (and rebuilding) Mona Lisa...maybe he has photos.
gotojoe likes this.
post #8 of 21 (permalink) Old 10-25-2018, 05:30 PM
R1andrew's Avatar
I don't think i have any pics of the stand. I supported the engine on the bolts like in the pic above. Used two supports up front and two in the rear. It was was OK for working on and swapping the frame.
MV Agusta F4 Superleggera (Mona Lisa)
MV Agusta F3 Ago 2015
Ducati 1098 2009
R1andrew is offline
post #9 of 21 (permalink) Old 10-26-2018, 07:10 AM
gotojoe's Avatar
Originally Posted by Pulse View Post
Thank you. Iíll probably end up with something built directly onto a wooden pallet. Would it be okay to carry all the weight directly on the sump?
I moved a 1090 engine with it sitting on a tire..
It is still sitting on a tire in the garage !
Joe
gotojoe is offline
post #10 of 21 (permalink) Old 11-05-2018, 03:04 AM
gotojoe's Avatar
Only teasing but I have to ask,
Did Andrew use Balsa wood for his stand !
joe
gotojoe is offline
