MV won't start - MVAgusta.net
 2Likes
post #1 of 26 (permalink) Old 10-21-2018, 07:44 AM Thread Starter
nonam3k's Avatar
MV won't start
Hallo. Got a new battery for my f1000r went to fit it and got it wrong way round put the neg on the positive .
When I turn on the ignition, there is a speedometer test and I can hear the pump but when I press the start the starter does not work. When it gives ground to the orange-yellow wire of the Solenoid, the starter turns on, there is a spark, the pump is running but the ECU does not give a signal for the injection.
A list of things I checked or bought new ones.
ignition switch - I checked OK
engine kill switch - I checked OK
gearchange position switch - I checked OK
general relay -I checked OK
starter buton - I checked OK
clutch level position switch -I checked OK
contact connector - I checked OK
Faulty fuse (E-5) - I checked OK
diode - New
Open circuit of the wiring - I bought a second wiring loom and also does not work
I ran jpdiag
Injection test OK
Fuel pump test OK
Test spark plug OK
The starter still does not work. Does anyone have any ideas? Broken ECU which does not give a signal on the solenoid?
Someone has for sale ECU for Agusta 1000r 2007-2008 without immo
nonam3k is offline
post #2 of 26 (permalink) Old 10-21-2018, 09:16 AM Thread Starter
nonam3k's Avatar
My computer has numbers 5ZDYJRI9G - 61601.347.02
I have found Ecu with this number: 5ZDH3Y93H - 61601.347.02
will he fit?
nonam3k is offline
post #3 of 26 (permalink) Old 10-21-2018, 09:23 AM
If it is a 5SM it will fit. The issue is the programming. If that ECU was in a 2007/8 1000R, then all is well. Otherwise you will need to have the CU flashed to your engine.
post #4 of 26 (permalink) Old 10-21-2018, 10:07 AM
Interested in your AC refrigerant fault code..... didn't know air conditioning was an available option !!
That fault code may have a different meaning for your bike and is worth looking at.
The TPS reading is also wrong and needs resetting. Should be 2.3.
I think the 61601.347.02 is the part number, and the 5ZDH3Y93H is a batch or serial number. Sounds like the ECU you found would work.
post #5 of 26 (permalink) Old 10-21-2018, 11:39 AM Thread Starter
nonam3k's Avatar
The seller wrote to me that Ecu is from 2007 MV Agusta F4 312R , in the evening has to send me a photo sticker with numbers
I think the 61601.347.02 is the art number, and the 5ZDH3Y93H is a batch or serial number. Sounds like the ECU you found would work.
I think that the error p0530 can be caused by disconnecting-AIR VALVE
The second error shows o2 sensor? My two wiring looms do not have an o2 sensor plug.
nonam3k is offline
post #6 of 26 (permalink) Old 10-22-2018, 06:54 AM
That ECU and its internal programming will work on your 1000R...but it won't be optimum.
Read this: https://www.mvagusta.net/forum/21-cu...-east-usa.html
We had trouble with the mapping being different in the 312R. My map flashed into a 100R ECU didn't work well as I recall.
@R1andrew, @Draginknee might remember
post #7 of 26 (permalink) Old 10-24-2018, 02:40 AM Thread Starter
nonam3k's Avatar
Thx. I ordered ECu 312r . I have 3" sports exhaust system and 4 x k&n filters without airbox , so may be good on this software.
The difference between 1000r and 312r is only software or the engine has different specifications?
nonam3k is offline
post #8 of 26 (permalink) Old 10-24-2018, 06:56 AM
WHAT??? you dumped the airbox and put little K&N pods on the intakes??? You just totally ruined your tuning. Lost a lot of horsepower too. Why did you do that?
And what is a 3" sport exhaust?
Whatever ECU you get, someone is going to have to do some dyno remapping to get your bike to run worth a crap....and it will still be down on power with K&N pods instead of the proper air box.
post #9 of 26 (permalink) Old 10-24-2018, 07:24 AM
The engine internal have different specifications.
As Ed said, why would you do what you did to that bike?
Could you post some pictures of this, um, modification?
post #10 of 26 (permalink) Old 10-24-2018, 09:50 AM Thread Starter
nonam3k's Avatar
Small filters, I do not think . The filters have a 58mm mounting diameter (in my opinion the engine will get more fresh air than with the original airbox). Gentlemen, I do not have an MV agusta motorcycle, the engine is mounted in Buggy.
nonam3k is offline
