Feared disaster with the B4 750!!!! - MVAgusta.net
post #1 of 12 (permalink) Old 10-09-2018, 11:55 AM Thread Starter
Snatched an 80 mile ride last Friday afternoon and all seemed well, until I arrived home, da da dah!!
I always have a quick visual around any bike I've ridden before I garage it. This time I was met with an oh no situation! There was a small divot of alloy punched off the outer surface of the sprocket cover, and I could see the head of an M8 bolt in the hole! Unfortunately, I was needed elsewhere and haven't had time to investigate since then, and have been sick with anxiety ever since!
All sorts of scenarios were circulating my cortex, but, there was no oil leak evident so I sort of convinced myself it couldn't be serious, could it?!
Finally, this afternoon I found 30 minutes to delve further, not without trepidation!
So, I popped the sprocket cover off, well almost, it's hampered by a cable which I guess is the speedo sensor? Anyway, the culprit was immediately obvious. An M8 bolt, which retains a toothed wheel to the sprocket shaft, had backed out and because it's rotating with the drive sprocket it had just forced it's way through the cover! I'm guessing again that the toothed wheel activates the speedo sensor?
So, disaster averted! Although, I bet the sprocket cover isn't a cheap part!! Nothing simple on these beasts!
I had took a break mid journey and the problem wasn't evident then, so it must have happened on the return run. It's possible things could have been worse had the journey been longer. Small mercy's then.
The only unusual thing I noticed on the trip was an erratic gear indicater, not sure if thats associated with the area at fault.
I'll make a parts enquiry tomorrow, braced for impact
INTERNAL COMBUSTION RECREATION FOREVER
brutant is offline
post #2 of 12 (permalink) Old 10-09-2018, 12:30 PM
Ah yes, the backed out speed sensor reluctor bolt and subsequent hole in cover. Seen it on bikes other than MV. Except for the damaged cover there isn't much bad that can happen.
That cover may be found used inexpensively....same part on all the first gen 4 cylinders. R1andrew may have one...he replaced the original with an overpriced bit of billet prettiness a long time ago.
Hint, use some loc-tite on that bolt when you torque it back down.
post #3 of 12 (permalink) Old 10-09-2018, 01:26 PM Thread Starter
Bolt now Loctited! Don't really like billet ally but if there was a Carbon one, hmmmmm!
brutant is offline
post #4 of 12 (permalink) Old 10-09-2018, 05:52 PM
Maximum Velocity's Avatar
Well don't say that I did not warn you ;-)
https://www.mvagusta.net/forum/20-ma...mes-loose.html
What a beast of a motorcycle!
Maximum Velocity is offline
post #5 of 12 (permalink) Old 10-09-2018, 06:45 PM Thread Starter
Before my time!! I didn't buy this Brutale until July this year.
Are there any other bolts that have a habit of becoming loose?!
brutant is offline
post #6 of 12 (permalink) Old 10-09-2018, 06:56 PM Thread Starter
For those that may be interested!
brutant is offline
post #7 of 12 (permalink) Old 10-09-2018, 07:20 PM
A little JB Weld and that will buff right out !!!!
post #8 of 12 (permalink) Old 10-09-2018, 07:33 PM Thread Starter
JB weld botchery on an MV, never gonna happen!! I do have a friend that could TIG it up but it would need alot of dressing and then painting, too much hassle. If I can find a mint used part, that would be fine but if not then new it will be!
brutant is offline
post #9 of 12 (permalink) Old 10-09-2018, 07:41 PM
Exclamation ?
brutant;
You don't know how bolts are measured
It's an M6x20
Dunlop likes this.
post #10 of 12 (permalink) Old 10-09-2018, 07:44 PM Thread Starter
Ooops!
brutant is offline
