Need some help 2013 F4 RR - MVAgusta.net
post #1 of 3 (permalink) Old 10-03-2018, 07:23 PM Thread Starter
First off i have to say this bike has been amazing ! other than regular maintenance and tires no major issues only thing that ever went on bike was cam chain tensioner , I can here to Mv Net and did research found that a Kawasaki dirt bike ran the same tensioner and replaced it !
I now have a small issue with rear tail light , i am aware its a sealed unit, but i know there is a fix for the loose connections in the wiring within the sealed tail light unit .
I have ruled out any other problems and if i tap on the tail light its self the running lights will come on but due to vibration they will quickly go out again , the front break and rear break lights are fine , just running lights are out ,
does anyone have a step by step on how to open the sealed unit and do a fix on the wiring , before i look into buying a new tail light $$$$
thanks guys ! proud MV owner up here in Canada !
rulookin is offline
post #2 of 3 (permalink) Old 10-05-2018, 12:27 AM
Tony F's Avatar
Hi
I had a similar problem with the rear indicators on my F4RR which stopped working due to water getting inside. I found a car light specialist who opened them up replaced the necessary parts to get them working again and resealed them. You might be able to track down some similar expertise. Otherwise just have go! Its not working as it is. And let us know how you get on.
Tony F is online now
post #3 of 3 (permalink) Old 10-05-2018, 09:59 AM
There's always upgrading that thing to a smoked lens. Probably only $100-$120. Check the forum sponsors.
2014 F4 RR
2008 Yamaha Raider S
1982 Suzuki GS850L
fingertight is offline
