Broken down - MVAgusta.net
  • 1 Post By Limpwrist
post #1 of 10 (permalink) Old 09-27-2018, 12:48 PM Thread Starter
Broken down
Hi. My 1090RR (2010) has stopped on a motorway. dash initially said engine fault-coil 1, 2,3,4. Also, my sat nav indicated no power. Now I have nothing on the on the dash, nothing works at all.
Any ideas? Maybe the battery has died or??
Limpwrist is offline
post #2 of 10 (permalink) Old 09-27-2018, 01:02 PM
gotfolk's Avatar
Start with your battery and make sure the wires have not become loose from it.
IF the wires are tight, check the battery to see IF it is just dead.
Next look over all the connections on the wire harness and make sure nothing is corroded and has become broken or loose.
Ironically I will be doing this with my 2012 1090RR here soon... (I put a new battery in and still having the same issue, so it is time to dive into the harness and find it)
2015 Yamaha FJ-09
2012 Brutale 1090RR
2005 Yamaha R6 - Sold
gotfolk is offline
post #3 of 10 (permalink) Old 09-28-2018, 04:50 AM Thread Starter
rectifier
Seems like the rectifier is the problem. Anyone know which Jap one fits? I am on holiday and need a quick fix to get me home.
post #4 of 10 (permalink) Old 09-28-2018, 04:51 AM Thread Starter
rectifier
the battery is not charging, output from alternator is good. there was no warning on the dash, the thing just stopped.
post #5 of 10 (permalink) Old 09-28-2018, 09:37 AM
Pretty much all regulator/rectifiers are made the same way (different capacities for larger alternators of course). Just packaging and connections differ. Pick any Japanese liter bike and see if you can change the connectors to match your bike. Should work just fine.
post #6 of 10 (permalink) Old 09-29-2018, 12:49 AM Thread Starter
It's fixed!
Managed to find a used rectifier, fitted it but still not charging.
Gave up and had it collected by the local MV dealer in Basel. After we told the mechanic what we had done, he went straight to the connector on the starter solenoid. It was blackened and the wires were exposed and fused together. He replaced the connector and wires and we were back on the road within 2 hours.
I should have had it done before the hol, but it had done 17k miles and I thought mine was ok. Wrong.
post #7 of 10 (permalink) Old 09-29-2018, 08:07 AM
I wish I had not been out of communication for this one.
The starter solenoid connections are always the first suspect in this situation.
There are many threads about this.
post #8 of 10 (permalink) Old 10-02-2018, 05:25 AM Thread Starter
Returned from holiday and thought I should complete the story.
The holiday plan was to ride down the route grande alpe, and then back up the route napoleon.
After 300 yards of the 330 mile ride to the channel tunnel, the gear lever return spring broke. When I returned to the house, my mother asked whether I had forgotten something-I asked her to put the kettle on while I got the toolbox out.
Got it fixed (the spare spring was under the seat, as a result of stuff on this forum) and set off again the next day, albeit in a pretty fragile state of mind.
After completing plan A, decided to spend a couple of days in the Vosges. Unfortunately, this involved travelling through Switzerland. The A2 around Basel was very busy and I had to filter for mile after mile in 28 degree heat. Eventually the bike stopped, and I just managed to get to the hard shoulder. I was 30 yards from the 3 kilometre long Belchen Tunnel, I donít like to ponder the outcome had it stopped in there. Nothing electrical working. Left the bike there and got to a hotel in Basel. Returned the next day with a battery and it started, but battery not charging. Rode it to the underground car park at the hotel for further investigation. Alternator output good so suspected the rectifier. New rectifier made no difference. Spannerís were thrown around the car park. When calm was restored and rational thoughts possible, I called the local MV dealer and they collected the bike. The mechanic went straight to the solenoid connector, found the burned block and fused wires and replaced them and I was back on the road to the Vosges within 2 hours. I regret not investigating this myself, but there was no obvious burning as there is in photos of affected bikes on this forum. Also, the stress of the situation did hinder rational thought. For info, the dealer is Shamal Garage, who,were excellent.
Anyway, completed the Vosges ride and the return home. 2800 miles in 2weeks, in great weather, on a fantastic MV Agusta, on the best roads on the planet.
The problems should not have happened, but I wonít slag or defend the bike. They cost me 2 days holiday lost, I usually lose several days fun to rain.
I suppose I will have to decide whether to trust the bike on next years long trips, will these type of things recurr?
Iíve ordered another 2 gear springs, and will consider what if anything can be done to prevent the burning of the connector/wires. The long filtering in 28degree heat, with the fans on for long periods probably found out the weakness. Maybe if the headlight could be switched off to reduce the current draw it might help?
One last thing, everyone should ride an MV Agusta on the N85 from Grasse to Grenoble once, preferably, a lot!
esq'z me likes this.
post #9 of 10 (permalink) Old 10-02-2018, 05:36 AM
Nice tale.... the spring, once replaced with improved type, should not break again. The electrical connector, once repaired and tight with no electrical resistance, shouldn't get hot again.
I'd take it on that ride with no concerns today if it were me. Wish I could !!
post #10 of 10 (permalink) Old 10-02-2018, 06:41 AM
Another you may do to improve electrical reliability in that area around the start solenoid is to get better cables from a company like Motoelectric.
