2015 F4RR - 6th gear issue - MVAgusta.net
 2Likes
post #1 of 11 (permalink) Old 09-16-2018, 05:41 AM Thread Starter
iwannagofast's Avatar
I have a 2015 F4RR which has a full termignoni exhaust and has had a tune.
The bike runs fine but in 6th gear sometimes the bike will display a malfunction error.
It only ever appears when in 6th gear and can come on and disappear by itself.
If I drop down to 5th the message disappears.
I can’t have MV run diagnostics as it will upset the aftermarket tune.
Could this be a speed senors or gear sensor?
2014 CBR 500r - SOLD
2013 MV Agusta F3 800 (written off)
2015 MV Agusta F4RR
iwannagofast is offline
post #2 of 11 (permalink) Old 09-16-2018, 07:28 AM
What is the malfunction message or code?
post #3 of 11 (permalink) Old 09-16-2018, 08:12 AM Thread Starter
Just says Malfunction with a symbol being a triangle with an “!” in it. No code shown on screen
2015 MV Agusta F4RR
post #4 of 11 (permalink) Old 09-16-2018, 10:12 AM
dansoarr's Avatar
Yep seen that, it just says malfunction and does not store the error as it gets resolved as you change gear.
It appears to be linked to the gear position sensor. Mine had significant tarnishing on the 6th gear pole. I removed it and used 12 micron lapping film to take the tarnish off the poles and plunger. 2000grit paper would do nothing too course.
I had the error pop back up last week, so need to clean again, it may be that the resistance of the sensor is on the edge of spec when warmed up. Mine only ever occured in 6th at higher rpm. I might check the 5v ECU output before I clean it again just to check.
esq'z me and iwannagofast like this.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #5 of 11 (permalink) Old 09-16-2018, 06:47 PM Thread Starter
That sounds like it could be my issue. Is it had to get to the gear position sensor?
2015 MV Agusta F4RR
post #6 of 11 (permalink) Old 09-19-2018, 10:50 AM
dansoarr's Avatar
Its easy, just on front of the gear change, held in by two bolts.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #7 of 11 (permalink) Old 09-19-2018, 04:37 PM
I had to order a new sensor recently (cracked and leaking), they were not expensive so I ordered one for road shift and one for GP/race shift.
This one is for GP shift I think.
Eitherway if I remember correctly it was only around 60 euros from Evolution.
Dragster 800 2015
F4 RR 2013
F3 675 2012 Full Track Bike
Brutale 1090 RR 2011 - Sold
jhollis is online now
post #8 of 11 (permalink) Old 09-19-2018, 04:44 PM
dansoarr's Avatar
Is that for the reverse shift drum?
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #9 of 11 (permalink) Old 09-19-2018, 04:57 PM
I believe so. When I ordered a replacement i got one of each just incase i moved to race shift, the other was installed on the bike and i am still running road shift.
The part number on the bag is 8A00B2607 however I cannot be certain this is the bag for this sensor as i ordered 2 and they were both stuffed into it.
I think the cable is longer on this one?
Dragster 800 2015
F4 RR 2013
post #10 of 11 (permalink) Old 09-19-2018, 05:38 PM
revhead1957's Avatar
As a side issue, I don’t understand the assertion that hooking up to the diagnostic will upset the custom tune.
Do you have the Eldor ecu?
In my garage: 2011 Brutale 1090RR, Triumph Street Triple R
revhead1957 is offline
