Tach needle fell off - MVAgusta.net
 2Likes
  • 2 Post By needragger
post #1 of 4 (permalink) Old 09-15-2018, 12:11 AM Thread Starter
Rode my '06 F4 to work today and she's been parked for a couple of months. Everything felt fine but it was a hot day for sure and the bike was probably exposed to direct sunlight for a few hours. On my ride back I look down and the darndest thing ..the tach needle is gone 😮 It's sitting at the bottom of the meter.
Now before I go taking it apart, I was trying to find any information on whether the console is serviceable ? Anyone know if I can get to the tach or if it's sealed ?
Thanks in advance.
needragger is offline
post #2 of 4 (permalink) Old 09-15-2018, 07:21 AM
Yes, the dash can be opened up.
To the best of my knowledge, the needle is simply pressed on. There ar folks here who have changed the face of their tach. @R1andrew comes to mind.
Those folks can advise.
post #3 of 4 (permalink) Old 09-15-2018, 03:32 PM
R1andrew's Avatar
It is not sealed. Just remove the screws on the back and pop it open.
MV Agusta F4 Superleggera (Mona Lisa)
MV Agusta F3 Ago 2015
MV Agusta F4 1000 Senna #25
Ducati 1098 2009
R1andrew is online now
post #4 of 4 (permalink) Old 09-17-2018, 12:47 AM Thread Starter
Thanks guys. You were right. The disassembly was smooth and took about 5 mins including removing the nose fairing.
I was able to fairly easily get to the tach. There was a little semi-circular metallic piece that was also rattling in there with the needle. It seemed to fit in the back of the 'hub' portion for the tach needle and had a hole in it which aligned with the little stubs on the back of the needle. I assumed it was a damping weight and glued it to the back of the hub. Aligning the ~1mm holes was tricky but it's all back together and seems to work. I'll update here if I have issues with it again.
Thanks again
R1andrew and silentservice703 like this.
