Lighting issue/ taillight - MVAgusta.net
post #1 of 6 (permalink) Old 08-01-2018, 01:34 PM Thread Starter
Jokrbrand's Avatar
Seem to have lost my taillight and the front led. All fuses are good. Brake light and turn lights all work. If I turn key to park position taillight and front led work, just not in run position. Any suggestions where to look for a bad connection?
12 F4R 7k miles
If it helps I got caught in the rain last rideout
Jokrbrand is offline
post #2 of 6 (permalink) Old 08-01-2018, 04:23 PM Thread Starter
Jokrbrand's Avatar
I've checked the connection at the light, ther right control for continuity pins 2-8, checked headlight plug. Does anyone know where these get power? I feel the park position is another circuit
post #3 of 6 (permalink) Old 08-02-2018, 06:15 AM
From what I can see, using a 2013 F4 wiring layout, the fuse that controls those lights is F3. It is a 7.5 amp fuse.
Did you test fuse continuity with a meter?
If the fuse is good, then I would suspect a short to ground on the BROWN wire with a BLACK stripe.
This controls all "Position Lights" the Tail Light and the License Plate Light.
post #4 of 6 (permalink) Old 08-02-2018, 09:11 AM Thread Starter
Jokrbrand's Avatar
Thank you. I have checked all fuses for continuity, voltage on both sides with a meter and test light, and connections. I'm wondering if it's in the key switch or maybe the plug just haven't tore it down that far. My schematic is poor quality. I can't really tell wire color or pins. The odd part that still boggles me is they work if the key is in park position.
I can power up the + wire to the taillight and everything works like it should with external power
post #5 of 6 (permalink) Old 08-02-2018, 09:39 AM
Arrow Please get the latest manuals!
It took me ten whole minutes, but here is your diagram and where you can download it for free. Donsy's website: Team Double 3 Racing | MV Agusta has your manual in the form of Edition 3 of the F4 manual/ Location and excerpts posted below.
It works great~! This isn't a treasure hunt folks...the information is at the TOP of every maintenance section in a sticky thread...and has been for years now!
Of course if you want this kind of service all of the time, then please PayPal me $100.00 each time I something that is easily done by yourself. My PayPal: [email protected]
post #6 of 6 (permalink) Old 08-02-2018, 09:01 PM Thread Starter
Jokrbrand's Avatar
Wow.... mine won't blow up like that and th link is broken.....
