High charging voltage - Brutale 1090rr 2010 - MVAgusta.net
 2Likes
  • 1 Post By misty5
  • 1 Post By esq'z me
post #1 of 5 (permalink) Old 07-04-2018, 10:44 PM Thread Starter
jrebollo's Avatar
Hi,
Today, I started my brutale after two weeks and after a few minutes idling, I noticed that the battery voltage spiked to at least 17v (I have a voltage meter installed) and shortly after the bike died. I started the bike again, and it run for about 30s, showing the normal voltage which is about 14v, and the voltage spiked again and the bike died. I'm guessing I have a bad regulator, does it make sense? Could it be a different issue? A month ago I was driving and the dash started flickering, and shortly after the bike died. I had to jump start the bike, since the battery was dead, but I made it home, and no issues for the next 60 miles or so. Not sure if it could be related.
I apologize if there is already a thread covering this, but I could not find info related to high voltage at the battery. Thanks.
jrebollo is offline
post #2 of 5 (permalink) Old 07-05-2018, 02:28 AM
falcn's Avatar
A true 17V would mean your reg/rectifier is dead.
If you jumped from a running car it could have damaged something. But a dead battery while riding indicates that the battery is probably not charging, due to bad regulator or bad alternator/generator.
falcn is offline
post #3 of 5 (permalink) Old 07-05-2018, 04:11 AM
Hi, Should be the reg/rectifer like already falcn told
Never jump energy from a car runnig, in most of time you'll damage something
falcn likes this.
misty5 is offline
post #4 of 5 (permalink) Old 07-05-2018, 10:03 AM
Yep...you've killed the regulator. Do not try to ride with voltage that high or you might damage something else!!!
falcn likes this.
post #5 of 5 (permalink) Old 07-05-2018, 10:42 AM Thread Starter
jrebollo's Avatar
Thanks for the feedback. I used a portable jump starter, so that probably didn't kill it. I'll replace the regulator, hopefully that fixes the problem.
jrebollo is offline
