Odd tap/knocking through L/H footpeg?! - MVAgusta.net
post #1 of 2 (permalink) Old 07-02-2018, 12:49 PM Thread Starter
BvG
BvG's Avatar
Question Odd tap/knocking through L/H footpeg?!
Evening Chaps (UK it is anyway),
Recently purchased a 1078 F4 '09 and she's beautiful! However there is an slight odd tapping, like someone flicking the bottom of my boot through the l/h footpeg - and a little transference to the right.
It seems to be throughout rev range/speed and initially i thought maybe just a bit of chain slap knocking but im not convinced. Having zero knowledge of F4's i thought i'd join up here and see if anyone has experienced similar issues.
Its not a regular, cycling tap - more like a baby pigeon trapped in a cardboard box with varying degrees of panic flappage...
All runs smooth generally, great power - clutch is a bit 'difficult' but understand this may be the nature of the bike.
Perhaps a final drive issues/bearing? Cam chain?...
I will add its more apparent on constant throttle..
Anyway, all advice very welcome!
thanks
BvG is offline
post #2 of 2 (permalink) Old 07-02-2018, 03:28 PM
revhead1957's Avatar
How many miles has the beast done? Has it been subjected to your winter roads?
FWIW, at 60000kms I have had to renew the aluminium bushes that are inserted in the shock mountings as they were getting quite sloppy (6mm movement at the wheel). I have also had to work on the Cush rubbers regularly. The goat tracks that our government tells us are roads are really harsh on vehicles in my area.
I would be going over the rear end and drive, looking for any excessive clearances.
revhead1957 is offline
