2007 MV F4 R fuel pump replace - MVAgusta.net
 6Likes
post #1 of 20 (permalink) Old 06-06-2018, 02:38 AM Thread Starter
Ozboy's Avatar
Hey guys,
Its been a long time since I've been on here, work and family commitments always take most of our time.
Anyway, I thought it was time to get the F4 back on the road as I haven't ridden it in over 4 years. Unfortunately I fell into that trap of connecting the trickle charger then putting the cover on the bike and forgetting about it.
Big mistake, I replaced all the fluids recently and realized I hadn't drained the fuel tank years earlier. There was about 4 litres of "varnish and treacle" in the tank.
Needless to say, the pump did not prime when turning the key.
So off came the tank and out came the pump and this is what I found.
The oem hoses are rubbish, they have completely fallen apart and the hose clamps are a nightmare to undo without the pliers. The main O ring seems to have a notch out of it (Is that meant to be there? )
This is a work in progress, so I'll update as I move through the process. But here are the photos of the pump uninstalled.
07 F41000R
09 Blazing orange Speedtriple
07 CBR 600RR trackbike
Ozboy is offline
post #2 of 20 (permalink) Old 06-06-2018, 04:34 AM
EVO Chris's Avatar
wow, that's decayed nicely, what's in your fuel! The o'ring should not have the cut in it, that may leak if you reuse......time for new one me thinks. Good luck with the rebuild.
Ozboy and Ozboy like this.
MV F4 750 EVO3 2003
MV Brutale 910s 2007
Honda VFR800 1998
Honda MBX 125 FE 1983
F4 Agusta mini moto replica
EVO Chris is offline
post #3 of 20 (permalink) Old 06-06-2018, 07:06 AM
The o-ring gets cut by a notch in the tank mating surface. There are threads about this. Easy preventive measure is to build up and shape epoxy to smooth that notch out. You need a new o-ring. Available from McMaster-Carr for pennies. Again, documented in other threads.
Click-R clamps can be unlocked with a small flat blade screwdriver, but you really should invest in the proper pliers...available on e-bay among other places. Again, documented in other threads.
Take the pump and jump it to a 12 volt battery to test if it runs. Sometimes a pump frozen with dead fuel can be "shocked" into movement with a direct battery jump start. Can also be submerged in carb cleaner to dissolve the gum.
Filter is available in auto parts stores. Common part number is documented in a prior threads. So is the fuel hose.
Time for a little "Search" and read.
post #4 of 20 (permalink) Old 06-06-2018, 09:04 AM
@Ozboy: I have everything here to supply you with the correct rubber parts, o-rings/J30R10 hose etc. for the rebuild. The Mahle filter is available from the web...or you can get an aftermarket equivalent.
Do what Ed says for your pump, and if you can't find the parts you need locally, let me know and we'll work something out.
post #5 of 20 (permalink) Old 06-09-2018, 10:08 PM
Ozboy;
The correct Clic-R pliers are available on eBay for $8-9 with free shipping
Don't waste your time trying to remove them with a screwdriver
post #6 of 20 (permalink) Old 06-10-2018, 01:56 AM
nigelrb's Avatar
Wow! A harsh lesson and perhaps a friendly warning to others. I hope you get it resolved with haste because the F4 is too good to not ride, let alone over 4 years.
2007 MV F4 1000R
2001 CBR9290RR Erion Racing Edition; 2003 CBR954RR; 2018 CBR1000RR SP2; 2020 CBR1000RR-R SP on order;
2002 VTR1000 SP-2; 2018 Honda C125 Super Cub
1985 VF1000R ('F' series); 1985 NS400R ('F' series);
2020 Triumph Daytona Moto 2 Limited Edition
nigelrb is online now
post #7 of 20 (permalink) Old 06-10-2018, 02:08 AM Thread Starter
Ozboy's Avatar
Thanks for the help guys. I've sourced the parts from a local dealer, who has also supplied the worm drive clamps ( I do like them)
Evo Chris, the fuel had been sitting for about 4 years, it was premium 98 ron fuel. I've scraped the gum off the main pump housing. so its looking a little more civilized now
07 F41000R
Ozboy is offline
post #8 of 20 (permalink) Old 06-10-2018, 05:58 AM Thread Starter
Ozboy's Avatar
Put everything back together and now I have all the dash lights flashing when starting, although the bike still won't start.
The pump does prime and the engine kicks over, but doesn't fire up.
Does anyone know what the flashing dash lights is alluding to? Can't find it in search.
07 F41000R
Ozboy is offline
post #9 of 20 (permalink) Old 06-10-2018, 08:38 AM
Poor battery voltage.
post #10 of 20 (permalink) Old 05-13-2019, 09:33 AM
Hi Folks,
I have the EXACT same issue.
I was wondering if someone could tell me the size of the hose between filter and pump and filter and assembly. I have seen 2 sizes mentioned on different threads. 1/4 & 5/16. I know it is J30R10 that I need but just need confirmation on the size!
Many Thanks!
Explodingtoad is offline
Tags
fuel pump not priming, fuel pump replace, long-term storage, oem fuel pump hoses
