F4 1st gen gearbox output shaft end-float - MVAgusta.net
  • 2 Post By bono
post #1 of 7 (permalink) Old 05-19-2018, 04:51 AM Thread Starter
2007 F4 1000R
I've recently changed the chain and noticed a significant amount(~5mm?) of end-float (axial play) on the output shaft from the gearbox.
The engine manual doesn't appear to list a tolerance range for axial play on this shaft but I was not expecting something to be so sloppy, unless it is designed this way to keep the front sprocket in line with the rear?
Anyone have any input/knowledge on this?
bono is offline
post #2 of 7 (permalink) Old 05-19-2018, 06:26 PM
bono;
end play should be the internal play of the CS bearing less than 0.1mm
You said you have ~5mm.....something is wrong
post #3 of 7 (permalink) Old 05-22-2018, 02:51 PM Thread Starter
bugger!
Thanks, I will have to go and double check as it would seem strange for it to be worn that badly. I guess you mean the one highlighted(3) in the attached picture?
I assume replacement would be clutch off, sprocket off and then gearset removal.
bono is offline
post #4 of 7 (permalink) Old 05-25-2018, 04:19 AM Thread Starter
So I'm not sure what I was thinking earlier, I went and checked it and there is zero play. I can only assume I had been wobbling it without the sprocket fully tight or just imagining it, thanks for the help though Noel
bono is offline
post #5 of 7 (permalink) Old 05-25-2018, 06:16 AM
That is good news.
post #6 of 7 (permalink) Old 05-25-2018, 06:59 AM
nigelrb's Avatar
That is good news.
. . . not to mention the stress and money saved!
2007 MV F4 1000R
2018 CBR1000RR SP2 : 2011 CBR1000RR : 2004 CBR1000RR : 2003 CBR954RR : 2001 CBR929RR (Erion Racing Edition)
nigelrb is online now
post #7 of 7 (permalink) Old 05-25-2018, 09:36 AM Thread Starter
Indeed, and passed MOT today with no advisories.
nigelrb and nigelrb like this.
bono is offline
