Rear Hub hot to the touch AFTER overhaul - MVAgusta.net
 2Likes
post #1 of 27 (permalink) Old 05-16-2018, 11:16 AM Thread Starter
Over the winter I decided to be proactive about the infamous rear hub issue and take a look at the bearings before it potentially became a problem. Having taken apart the hub, the sealed smaller bearing was indeed on its way out. Following the instructions elsewhere on this site, I replaced the bearing, re-greased the hub, and put everything back together again. I was especially careful not to over-torque the hub pinch bolts (28Nm) or over-tighten the chain (8mm slack). I thought the issue was resolved.. until I went for the first long ride of the season yesterday. The bike felt totally normal, but when I pulled over and felt the rear hub, it was hot to the touch. Not exactly scalding hot, but if I were to leave my bare hand wrapped around the hub, it would eventually become too hot to continue -- I would guess ~60 Celsius. I never did this prior to replacing the bearings so I have no point of comparison.
So i guess my question is two fold:
1) Is this kind of operating temperature out of the norm or am I freaking out over nothing?
2) If it is a problem, what else could cause this given the new bearings? Possibly too little grease? I wasn't sure how much is too much so I didn't go crazy, although I did re-grease the needle bearing thoroughly.
Bike is an 07 Brutale 910R with 17K miles.
tokesSV is offline
post #2 of 27 (permalink) Old 05-16-2018, 11:33 AM
Funny thing when you do something you have never done before.
post #3 of 27 (permalink) Old 05-16-2018, 12:20 PM
Whatever you do, don't touch that brake disc attached to the rear wheel !!!
post #4 of 27 (permalink) Old 05-16-2018, 12:31 PM
Teeps's Avatar
I wondered the same thing as the OP; but have yet to remember to touch the swing arm after a ride.
But you are right there will be heat transfered from the rear brake.
I rarely use the rear brake...
2016 Turismo Veloce 800
Teeps is offline
post #5 of 27 (permalink) Old 05-16-2018, 04:46 PM
MVAgusta.net Sponsor
mitchy's Avatar
I am sure you have nothing to worry about.The hubs run warm to hot.As mentioned heat transfer etc.
As long as you used a good quality high temp grease you are good to go.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
post #6 of 27 (permalink) Old 05-16-2018, 05:19 PM
Is 28nM the correct torque for those bolts?
Itís more than stated for my 2nd gen f4.
allanl is offline
post #7 of 27 (permalink) Old 05-16-2018, 06:47 PM Thread Starter
Thanks, mitchy! That's a relief... it's just one of those things that's not covered in the manual and that you can only learn from experience, or others' advice
tokesSV is offline
post #8 of 27 (permalink) Old 05-16-2018, 07:02 PM
Teeps's Avatar
see post #21 in this thread; http://www.mvagusta.net/forum/13-bru...djustment.html
20nM is what "theknurl" recommends, he is the proclaimed forum curmudgeon...
Teeps is offline
post #9 of 27 (permalink) Old 05-16-2018, 09:51 PM
mitchy's Avatar
You have done well.Ride and enjoy.
Bike- F4 1078 312rr
Mobile-0423041326
mitchy is offline
post #10 of 27 (permalink) Old 05-17-2018, 02:59 AM
Deano's Avatar
As mitchy said. I changed mine after the original shit the bed. The new one ran warm to hot, but I was using the rear brake back then. It gets used never to very little now for various reasons, mainly a much better front brake courtesy of a Brembo RCS19 master cylinder. Now it is only warm to touch showing how much heat transfers from the back brake.
Deano
Deano is offline
