fans not working - MVAgusta.net
 2Likes
post #1 of 20 (permalink) Old 05-12-2018, 01:32 PM Thread Starter
andrew fotheringham's Avatar
fans not working
Hi all, during a ride out my bike got hot but the fans never kicked in, they were working the last time I rode so I'm a bit lost. The temp gauge is fine as I got some speed and cool air going it showed that temp had dropped. All suggestions are grateful.
andrew fotheringham is offline
post #2 of 20 (permalink) Old 05-12-2018, 01:41 PM
Either the relay has gone pop or you have a small stone stuck under the fan blade like I did last time I rode thru wales....
merc07 is offline
The Following User Says Thank You to merc07 For This Useful Post:
post #3 of 20 (permalink) Old 05-12-2018, 01:45 PM
I'm with Adam on the relay....
post #4 of 20 (permalink) Old 05-12-2018, 11:20 PM
MVAgusta.net Sponsor
mitchy's Avatar
Check the fan fuse first,then relay.You can check if the fans themselves are working by grounding the black/white wire at the relay with ignition switch on.
If the fans come on,you need a new relay.
theknurl and theknurl like this.
Bike- F4 1078.
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
The Following User Says Thank You to mitchy For This Useful Post:
post #5 of 20 (permalink) Old 05-13-2018, 07:37 AM
Maximum Velocity's Avatar
I don't even have fans...
What a beast of a motorcycle!
Maximum Velocity is offline
post #6 of 20 (permalink) Old 05-13-2018, 09:04 AM
Don't forget there are 2 temp sensors......one for the meter and one for the ECU/fans.
post #7 of 20 (permalink) Old 05-13-2018, 12:44 PM
Ian SAVS's Avatar
Send a message via Skype™ to Ian SAVS
Ed's got a good point here And, I forgot that fact when we were talking about it, it could still be the ECU thermostat as well....
What we've got here, is failure to communicate.
Ian SAVS is offline
post #8 of 20 (permalink) Old 05-13-2018, 05:03 PM Thread Starter
Now i'm completely lost, it definitely isn't the fuse as I checked that today, my problem now is where is the relay located as it's not in the manual and do I have to take off the tank and airbox to fix this?
post #9 of 20 (permalink) Old 05-13-2018, 05:23 PM
mitchy's Avatar
Not sure what model you have,but the relay is normally right next to the fuses on the R/H side where your knee is positioned when sitting on the bike.Number 47 in this picture-
Bike- F4 1078.
Mobile-0423041326
mitchy is offline
post #10 of 20 (permalink) Old 05-14-2018, 12:13 AM Thread Starter
Attachment 440114
Thanks Mitch, I will look later and get back.The bike is a 2002 f4 1+1 750.
