What are these connectors for? - MVAgusta.net
 2Likes
post #1 of 28 (permalink) Old 04-19-2018, 01:40 PM Thread Starter
Smokeymurphy's Avatar
It’s a 2011 F4RR
Circled in red
“Shhhh my common sense is tingling”
2011 F4RR
Smokeymurphy is offline
post #2 of 28 (permalink) Old 04-19-2018, 03:50 PM
Probably turn signals.
post #3 of 28 (permalink) Old 04-19-2018, 04:02 PM Thread Starter
No the turn signals are accounted for on the fairing bracket, took the nose off and found these not connected to anything
2011 F4RR
post #4 of 28 (permalink) Old 04-19-2018, 04:21 PM
AgustaRod's Avatar
heated grip connectors ? looks like thats a TV
Keep your MV in good repair: motorcycle boots are not designed for walking.
AgustaRod is offline
post #5 of 28 (permalink) Old 04-19-2018, 04:33 PM
Ok, so here comes the $64.00 question: Have you looked at the wiring diagram and the manual?
I do not own a Second Gen F4...although there is one at the house right now...and that's what I would have to do to figure this out.
post #6 of 28 (permalink) Old 04-19-2018, 04:35 PM Thread Starter
Would they be?
I can confirm it is not a TV , RR corsacorta
2011 F4RR
post #7 of 28 (permalink) Old 04-19-2018, 04:36 PM Thread Starter
Yes but I can’t seem to find what these connectors are, flicking through pages of wiring diagrams
2011 F4RR
post #8 of 28 (permalink) Old 04-20-2018, 05:36 AM
Well, they are simple 2 wire connectors...perhaps the wire harness connectors to the turn signal connectors in the fairing bracket. Do they both have one wire the same color? That would be common ground.
They sure look like turn signal connectors. Not too many other options.
post #9 of 28 (permalink) Old 04-20-2018, 06:43 AM
OK, start the clock....
post #10 of 28 (permalink) Old 04-20-2018, 07:01 AM
Ok, fifteen minutes have passed and I have gone through the electrical diagram and the shop manual. The possibilities are: Nose LEDs, Turn Signals, Dash lights, Running Lights, ABS connections....
So, without the bike in front of me to know how many wires to each connector (looks like a three pin, but might only use two wires) and what color those wires are (peel back a bit of the sheathing) then you are on your own.
If you can give the the number and color of the wires, then I will give you your answer.
nigelrb and nigelrb like this.
