No abs in settings on 2013 f4 abs dashboard - MVAgusta.net
  • 2 Post By mrmerlin
post #1 of 10 (permalink) Old 04-15-2018, 04:41 AM Thread Starter
Clay1001's Avatar
Hey guys and gals
I have been having some speedo and ABS issues
The issue is now that I have unplugged it and plugged it back in, it is like it is not even there. The ABS light does not show up on the dashboard after starting the bike and most importantly the ABS SETTINGS no longer show up as I scroll through the settings.
Can anyone help me fix this issue? I have checked the fuses and they are fine, it just seams that the ABS system is no longer loading at start up....
Cheers Clay
IF LIFE THROWS YOU A CURVE, DROP YOUR KNEE AND RIDE THAT BITCH
Clay1001 is offline
post #2 of 10 (permalink) Old 04-15-2018, 06:29 AM
BSR-1's Avatar
I hope this doesn't come across wrong, I'm just curious.
Do you even need the ABS? I mean has it ever kicked in and saved you?
I just guess that tires (Front) are so grippy these days that they'd be almost impossible to lock up unless leaned over or in gravel or something.
2018 Husky 701 Supermoto
2018 Aprilia Tuono 1100
BSR-1 is online now
post #3 of 10 (permalink) Old 04-15-2018, 06:55 AM Thread Starter
Clay1001's Avatar
I actually never have my ABS turned on, I hate it..... But with the system not working the Speedo is not worki8ng either.......
Clay1001 is offline
post #4 of 10 (permalink) Old 04-15-2018, 07:41 AM
Back to the old mechanics saying: The new problem you are experiencing now is directly related to the maintenance you just completed.
post #5 of 10 (permalink) Old 04-15-2018, 07:41 AM
did you disconnect the battery and then connect it and try it?
I have used my ABS as it kicked in when over cooking a turn entry on cold tires
2013 Brutale 1090 RR ABS
Philly PA USA
mrmerlin is offline
post #6 of 10 (permalink) Old 04-15-2018, 07:50 AM Thread Starter
Clay1001's Avatar
Yes I did disconnect the battery and it didn't help. I am just very puzzled that just because I unplugged and plugged it back in means that it is no longer working...
Clay1001 is offline
post #7 of 10 (permalink) Old 04-15-2018, 08:57 AM
BSR-1's Avatar
Got it!
BSR-1 is online now
post #8 of 10 (permalink) Old 11-21-2018, 08:01 AM Thread Starter
Clay1001's Avatar
I try to finish off all my posts in order to hopefully help others.
The under lying issue with most of my problem has been one big issue.
I dropped my bike off to the boys at Cube Performance Centre on the Gold Coast the other day and they said they will find out what is going on...
And they did, it turns out the the radiator fans have been slowly cutting through the wiring harness which has caused most of my issues
Photos attached
A big shout out to Ben Henry and Richard and Cube Performance Centre...
I am so happy with these guys that I have decided to ditch my Rexxer tune and have them Dyno tune it with ECU studio on Monday
I will try and list results of my tune after Monday
Clay1001 is offline
post #9 of 10 (permalink) Old 11-21-2018, 08:09 AM
Well now...it seems there is another thing to check.
post #10 of 10 (permalink) Old 11-21-2018, 08:19 AM Thread Starter
Clay1001's Avatar
I had the whole wiring harness replaced under warranty three years ago. They obviously didn’t do a very good job keeping it clear of the radiator fans 😩😩😩
Clay1001 is offline
