ENG - Crankshaft Error - 2012 Brutale 1090RR - MVAgusta.net
post #1 of 26 (permalink) Old 03-17-2018, 05:35 PM Thread Starter
Hey All,
Went for a ride today and the engine stalled a few times. Finally got a fault message and got in on the GoPro. ENG - Crankshaft. Turned bike off and back on and she runs. Think it’s the crankshaft sensor?
eltsanwich is offline
post #2 of 26 (permalink) Old 03-17-2018, 07:03 PM
airjawed's Avatar
If the rpm goes low I think you will get that error. We see that error with sprag clutch issues in the 3 cyl platform. In our case it is a false error. I would look at other causes of stalling or low rpm.
airjawed is offline
post #3 of 26 (permalink) Old 03-17-2018, 07:21 PM Thread Starter
I’ve had the stall happen in 3rd gear around 4K and it cuts out for a second and then fires back up. Similar to your issue or just low RPM?
post #4 of 26 (permalink) Old 03-18-2018, 10:05 PM
Wink ????
Originally Posted by eltsanwich View Post
Iíve had the stall happen in 3rd gear around 4K and it cuts out for a second and then fires back up. Similar to your issue or just low RPM?
airjawed;
Try reading what he posted......his problem is at 4,000rpm......
Yours is at cranking speed
Your conjectures are annoying
The Cripples are nothing but issues......go back over the the 3 cylinder section and try to figure out
how a drain plug seals
post #5 of 26 (permalink) Old 03-18-2018, 10:18 PM
eltsanwich;
Try disconnecting the crank sensor and adding some dielectric grease on the pins and sockets and make
sure the plug latches back together firmly.....
The sensor has no moving parts, so either it works or doesn't, now the electrical connections are a different story
Try zip tying the connector firmly to the frame....that will eliminate a possible harmonic/amplitude problem
post #6 of 26 (permalink) Old 03-18-2018, 10:38 PM
airjawed's Avatar
I wasn't responding to eltsanwich last post. He responded after me... unless it shows differently in your thread sequence. I was responding to OP's original which didn't say 4K
If it is a low rpm stall then my response is it isn't the crank sensor and possibly a false.
If it is stalling at 4K then must investigate the sensor.
airjawed;
airjawed is offline
post #7 of 26 (permalink) Old 03-19-2018, 12:33 AM
Thumbs up ????
You just don't get it do you?.....
It's a passive pickup with no moving parts, it senses the passing of the phonic wheel.......either it works or it doesn't
The wiring is another thing......
Your problem with the Cripples is they went cheap......
Batteries
Sprag clutches
Alternators
Welding
And then they piled on the electronic bullshit
Enjoy your Cripple.....I was offered a killer deal on a TV by a friend with dealership ......I thank God I didn't buy the POS
My '08 Brutale 910R has 35,000+ mi .....used 2 low beam bulbs, the thermister for the low fuel light failed and the pin for the
side stand spring wore through, stock battery went 8 years, still on the original chain and sprockets
It gets ridden 365 days a year unless it's pouring rain
post #8 of 26 (permalink) Old 03-19-2018, 04:25 AM
dansoarr's Avatar
That's not 100% true, no moving parts is correct, but many crank sensors have a progressive failure, heat being one prime example. The sensor works when it is cold, as it heats up it starts to drift, miss pulses, or affect the duration / shape of the pulse leading to the ecu displaying an error. I've had this on race bikes (gsxr, zx) and cars albeit vauxhalls (opels).
as @knurl suggested wiring would also be my first port of call as its the mechanical but of electronics that tends to fail first, then the internal mechanical structure of the sensor.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #9 of 26 (permalink) Old 03-19-2018, 01:53 PM Thread Starter
So I disconnected the sensor and I am measuring 645 in its current state. I could have swore I read in a manual that had the impedance range specs but I cannot for the life of me find that. Do you guys have that info?
post #10 of 26 (permalink) Old 03-19-2018, 04:13 PM
airjawed's Avatar
The range is 680-700 for resistance and a gap of 0.6-0.7 at the wheel
airjawed is offline
